Some might probably remember this same car having a RB26/30 and a powerglide dummied up in it,
but after some calculations it was soon realised that this combination was going to cost tens of thousands
of dollars to complete the engine alone. So the engine & transmission were sold and the project put on hold.
Six months later i came across a low Km LS1 and Tremec 6 speed. For a laugh on a saturday arvo a friend and I thought
we would see if it would even look like fitting, the joke soon became a reality.
Factory Nissan engine mounts were used on the cross member, block to mount brackets were fabricated.
The sump did not need any modification. The factory power steer rack was removed and a VL manual rack was fitted to allow for starter motor clearance. VX Commodore 1&3/4" into 3" extractors were fitted with slight mods, just had to tuck them in a bit. PWR Radiator to suit R32 was purchased and custom shroud and fan fitted. Gearbox crossmember was fabricated
as well as custom tailshaft with masive F100 front Uni. Jim Berry supplied custom clutch and flywheel. Factory LS1 wiring harness will be fitted.
Custom fuel cell was modified to house two Bosch 040 intank pumps and plumbed up with speedflow fittings through a Russell
inline filter into turbosmart reg.
I plan on running the engine aspirated at first with just a cam and valve spring change. Should make 350kw at the wheels.
Hope to fit twin Disco potatoes later down the track.
https://www.sau.com.au/forums/topic/187852-r32-ls1-conversion/
  • Replies 812
It took about 4 hours to mount the engine and box, about the same to mount the rack. the headers took a couple of hours to modify, fuel system took about 8 hours. still have to wire it but that shouldnt take to long. could easily do it in a week if you didnt have to wait for parts to be made, eg clutch, tailshaft, radiator etc.
;) how long did it take from the initial fit to turning the key?
whats a proper V8? it makes you wonder why its been done heaps if Ls1s are shit. but u know what your talking about, ill pull it out tonight.
man it's been done heaps, ls1's are shithouse should of got a proper v8... afterall it's a holden.... but either way nice work....
Edited by BezerkR32
Nice work mate.
How did the weight of the LS1 and gearbox compare to the weight of the RB30, geabox, front diff and transfer case?
Twin Turb's FTW, should have fit them first. :thumbsup:
I'd say the new motor would be lighter than the old one but the gearbox from the Commodore is monstrous. This car never had a front diff or a transfer case btw. :D
yeh, the engine is lighter being full alloy and having plastic intake, the new headers are also alot lighter
than the cast ones. the flywheel will also be lighter as well as the clutch assy as we are going from the standard 12.5" truck setup to a 10.5" clutch, actually using a GTR pressure plate, but the Tremec is big, think of a R33 5 speed then add 20 kilos. Its all good though as the weight is in the middle of the car and the engine sits further back than the inline six also. The turbos are something i would like to do, but want to run the car aspirated first. turbos, manifolds, plumbing, pipework, intercooler would add about 80kilos to the front of the car and would cost about $5500, not just yet. hoping to make around 350rwkw aspirated and turn the engine to 7000rpm, should be fun in a car that ways 1000kg.
I'd say the new motor would be lighter than the old one but the gearbox from the Commodore is monstrous. This car never had a front diff or a transfer case btw. :laugh:
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
    • This sounds like a perfect excuse to install a Haltech R3.
