  • Replies 812
Yeah, thank god there is only 5 journals. Had to do it twice though, believe it or not but the crank tunnel was oval by half a thou. it was within spec but thought better to have it machined as this thing is going to see a bit more rpm than in standard form. Also had the oil galleries on the crank tear dropped. Just have to find some time to go and finish it.
Speaking of finish, the paint job is almost done. Boys painted the black top yesterday, they were blocking it back and re-painting it last night so cant wait to see it. ill post pics soon. Adrian has a few know, ill see if he will put them up. Had a pin stripe guy put some samples on the side of it, told him and the painter to sort it out as i couldn't choose. Also been talking to Ryan from ISC Coilovers about suspension components. He has been really helpful. I will be getting everything off him when i get to it, and can afford it Ha Ha.
nice hands stu.
showing off a new inside micrometer?
Ha Ha, very funny, in all seriousness, my daughter calls it bumblebee. she's 3 years old and a transformers freak.
now that its got a beautiful colour scheme whats it's name?
daisy?
muffin?
<insert gay yellow name here>
:down:
Have been fitting the car up for the last week, its amazing how you forget were stuff went or how it fit after 2 years, but slowly slowly. all door rubbers are back on, mirrors, fuel cell, pedal box, brake booster which i had out of a R33. had master cylinders serviced. Hope to finish engine assembily on saturday, well bottom end anyway. Bonnet is painted, have to fit pins with the panel beater. still waiting for boot lid. wheel centres are painted, waiting for outers to be polished. Post pics soon.
unfortunately no, unless you use a bellhousing that will accept starter on the other side, would also have to modify block as starter mounts on it. i have heard that you can get a kit, but am not 100% sure. might be able to find answers on ls1.com
any way around the power steering option??
Finally started work on the engine again on saturday. Cleaned block & crank, re-checked main bearing clearances which were perfect. Installed Cam bearings. Fitted crankshaft & camshaft.
Returned on monday hoping to have the same success with the oil pump, how nieve of me. It seems that the double row timing chain and hi-pressure oil pump combination was going to be a problem.
i made 3mm spacer + 1mm gasket to space oil pump forward to clear the now wider chain. this was perfect with the standard pump but the Melings pump body is wider, so i had to relieve it in a few spots with the die grinder to get sufficient clearance.
Now that that was O.K. i thought i would try the timing cover, and you guessed it, it wouldnt fit with the pump spaced forward. I replaced the oil pump cover bolts with cap head bolts to gain an extra 3mm clearance, relived the pump and cover in a few places and finally after about 2 hours got it to fit.
back in the evening to fit pistons. Rings were gapped earlier so were ready to go. Quick big end clearance check, then banged them in. all was looking good until it was found that the side clearance between the rods was tight as in V8s 2 rods share the same journal. so pulled 4 pistons back out to have the big end face machined. Will have another go tomorro. A bit frustrating when all of the bottom end is standard. just goes to show they slap em together in the factory.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
