  • Replies 812
Yeah, thank god there is only 5 journals. Had to do it twice though, believe it or not but the crank tunnel was oval by half a thou. it was within spec but thought better to have it machined as this thing is going to see a bit more rpm than in standard form. Also had the oil galleries on the crank tear dropped. Just have to find some time to go and finish it.
Speaking of finish, the paint job is almost done. Boys painted the black top yesterday, they were blocking it back and re-painting it last night so cant wait to see it. ill post pics soon. Adrian has a few know, ill see if he will put them up. Had a pin stripe guy put some samples on the side of it, told him and the painter to sort it out as i couldn't choose. Also been talking to Ryan from ISC Coilovers about suspension components. He has been really helpful. I will be getting everything off him when i get to it, and can afford it Ha Ha.
nice hands stu.
showing off a new inside micrometer?
Ha Ha, very funny, in all seriousness, my daughter calls it bumblebee. she's 3 years old and a transformers freak.
now that its got a beautiful colour scheme whats it's name?
daisy?
muffin?
<insert gay yellow name here>
:down:
Have been fitting the car up for the last week, its amazing how you forget were stuff went or how it fit after 2 years, but slowly slowly. all door rubbers are back on, mirrors, fuel cell, pedal box, brake booster which i had out of a R33. had master cylinders serviced. Hope to finish engine assembily on saturday, well bottom end anyway. Bonnet is painted, have to fit pins with the panel beater. still waiting for boot lid. wheel centres are painted, waiting for outers to be polished. Post pics soon.
unfortunately no, unless you use a bellhousing that will accept starter on the other side, would also have to modify block as starter mounts on it. i have heard that you can get a kit, but am not 100% sure. might be able to find answers on ls1.com
any way around the power steering option??
Finally started work on the engine again on saturday. Cleaned block & crank, re-checked main bearing clearances which were perfect. Installed Cam bearings. Fitted crankshaft & camshaft.
Returned on monday hoping to have the same success with the oil pump, how nieve of me. It seems that the double row timing chain and hi-pressure oil pump combination was going to be a problem.
i made 3mm spacer + 1mm gasket to space oil pump forward to clear the now wider chain. this was perfect with the standard pump but the Melings pump body is wider, so i had to relieve it in a few spots with the die grinder to get sufficient clearance.
Now that that was O.K. i thought i would try the timing cover, and you guessed it, it wouldnt fit with the pump spaced forward. I replaced the oil pump cover bolts with cap head bolts to gain an extra 3mm clearance, relived the pump and cover in a few places and finally after about 2 hours got it to fit.
back in the evening to fit pistons. Rings were gapped earlier so were ready to go. Quick big end clearance check, then banged them in. all was looking good until it was found that the side clearance between the rods was tight as in V8s 2 rods share the same journal. so pulled 4 pistons back out to have the big end face machined. Will have another go tomorro. A bit frustrating when all of the bottom end is standard. just goes to show they slap em together in the factory.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
