R32 Ls1 Conversion
BezerkR32
  • Replies 812
nah, you can just buy this one
haha. you planning on getting rid of it already? or just for the right price ay..
i was looking into doing this as a project but i think i'd get bored from how long it would take with available funds atm.
tell me about it, i sold brakes for $500 and have to spend $3500 to replace them.
grrrr it's 2:33am and i've been sitting here pretty much re-reading the whole thread haha!
makes me wana start mine right now. still got a lot of research though!
would you mind if i asked you a few question when i get stuck on mine?
wish me luck at work in 2 hours haha
Purchased a GTR style front bar ages ago, there is a pick of it somwhere earlier in the thread.
Some Vielside side skirts, and a GTR bonett to go on very soon i hope. Also bought a glass bootlid but it does not seem to be much lighter than the metal one. have to weigh it.
can you say 'race spec!'
What front bar are you using.. decent sized oil cooler too!
basically the same car, i cant see it being to much different. Spoke to SK today about a suspension package. You would be amazed on what i learned in 20mins on the phone. want to get the car running in the next few weeks and then sort suspension and then brakes. Might have to sell go-kart.
Can't weit to see this in action.. been waiting for an ls1 powered 32 for ages! So many ls1 s13's now though.
yea i was wondering what suspension you're going to be using seeing that you're using it as an all rounder.
Car has been at panel shop for last week getting fitted up. Had the boot sprayed also. Bonnet pins fitted etc and then a final buff, came up mad. cant believe it is the same car i picked up from Qld 18 months ago. this is the first time the car has had all the panels fitted.
Got the lifters today and should have the heads next week.
Pulling box back out tomorro to play around with release bearing clearance.
Cpmputer arrived during the week. Going to purchase some guages, finish the dash and get the car wired so i can fire it.
A few before and after shots.
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
