have some nice Rays gt2s for sale that woul be sick on the silvia... :)
My front suspension arms arrived today, so should have everythig fitted and the car on the ground this week-end. was hoping to have the engine assembled and fitted but have had an issue with valve spring retainers, so unless a replacement set arrives 2morro, the engine will probably go in next week.
nice. they were a good buy. I was nearly going to grab them as a spare set for the silvia. then remembered I already have 3 sets of rims for the silvia.... :banana:
Edited by BezerkR32
  • Replies 812
... and additional front diff support bracket.
Charles do you mean the one that goes under the nose of the diff? If so, ditch it. Only the 32gtr ran this extra bracket, 33 and 34 don't use it, and neither do some big power cars I know of with theis cradle. You just need some large washers to protect the lower bush
Picked up heads after sorting out the valve train issue which ended up being a dodgy set of locks. Got a new set of Manley locks and all was sweet.
ARP head stud kit, MLS Felpro head gaskets, Comp Cam anti pump-up roller lifters, Comp Cam pushrods & Yella Terra rockers. I know that the pushrods may be a bit foreign to some people. lol. Also fitted stainless ARP exhaust manifold stud kit, as they were cheaper than GM.
Comp ended up at 10.9:1 after the deck machine, which is excellent as standard is 10:1
Will finish setting up the rocker pre-load and sit the engine in tomorro.
Looking nice!
I hope you didn't mount the heads the way you are about to in the bottom left picture... It shows your about to mount the head in the wrong direction... (Exhaust port to the intake side...) :domokun:
yeh, was going to try something different, but it wouldnt fit lol. you dont miss much. :(
Looking nice!
I hope you didn't mount the heads the way you are about to in the bottom left picture... It shows your about to mount the head in the wrong direction... (Exhaust port to the intake side...) ;)
some hot rod guys told me there was 10kw in doing it.
Starting to bang it all together, all going sweet, i guess thats the advantage in triall fitting everything first.
ill finish fitting radiator, and dummy up engine harness so electrician can start. can also start buying bends for the exhaust
Should get a mechanic to do it, Stu.
they are off our Commodore. They are 1&3/4" primary pipes into 3". they had to be modified to fit but only slightly.
Nice!
Not long now until you can start it...
From witch car does the headers come from? Pontiac GTO?
And what are the spec on the headers?
thanks Phunky, still a while off though. hoping to have it all done for powercruise, that will give me the oportunity to run everything in and sort out any teething problems before i track it.
Looking good! Can't wait to see this thing in action
BezerkR32, amen to ya brother, forget the haters lol, mine makes 340hp on a completely stock engine with a link g4 ecu, ive owned many an rb20det and a couple work rb25dets and I have to say I enjoy my new setup the most by far. I did manage to retain my power steering though, although its so incredibly tight as you can see from the pictures, that it initially wore a hole in the starter motor:S I have the car running now, just havent updated the thread. Cant wait to see some action footage lol.
Video
http://www.bebo.com/FlashBox.jsp?FlashBoxId=8060454510
Build Thread
http://southernskylines.com/phpBB3/viewtop...f=24&t=2359
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
