R32 Ls1 Conversion
BezerkR32
Mate I'm still drooling waiting for this thing to be done!
I've been told from a reliable source and someone who's actually done some testing, that the std R32 GTR wing coupled with the Nismo lip spoiler actually does make a measurable difference btw....
  • Replies 812
the electrician was almost done, he reckons we should be able to fire it on saturday.
ill post some pics up. he had done engine bay, dash, and battery cable, relay and fuse box, was finishing powering up the ecu yesterday. might have to modify one harness for the tps switch and iac valve once new intake arrives as we are not sure where they are located. job is tidy, definately not autosalon quality but fuctional and easy to follow.
i wish it was as easy as just throwing the engine cover in there lol. been fun though. worst part is waiting for other people.
Always an excuse Stuart!
Mate, I started the engine swap into mine yesterday arvo.... she'll all in and running, was skiddin her up this arvo :rolleyes:
got car back today, wired and ready to start. Going to crank it for oil pressure later on tonight.
Still have to fit intake in order to fire it.
Took some pictures of ecu, fuse block and relay block. all fairly basic, mounted on passenger side floor.
once the car is running i will be able to cut some more of the chevy engine harness out as it is for the BCM and not necessary. Like mentioned earlier it is tidy and functional but not show quality. But at the end of the day its a track car. i might spend some time pinning the harness up later, once we know it all works.
lets not get excited, this could go pear shaped quickly. i guess once its running we can see if the decision was a good one. Riskings GTR carnage thread has given me hope lol. i guess they all look the same once they are busted up.
Looking good. I sometimes think I should've put an LS1 in my car...
nah, unfortunately didnt get much done. just made it a home in my garage, havent had it home before so spent most of the night organising the garage.
Everything go alright last night Stuart?
Not long now! :)
Looking great!
And with the wiring, the important thing is that it works... And anything is better than the origional wiring...
I am going to get my car from my cage builder this weekend, so I can finally work on the car again...
Good luck with the start up of the engine! :(
i bought one from JS Auto Imports, Unfortunately i didnt get to use it as it turned up after the car was painted. Risking bought it off me. It was well made. Not sure of the weight improvement. youll have to ask him.
Bootlid? I need a light weight one but cant find one...details my son, details ? :)
Bootlid? I need a light weight one but cant find one...details my son, details ? :P
There's a bunch of 'glass ones around, but no lighter than stock from what I can gain from those selling them.
I removed the hinges and torsion bars (approx 3.5kg), cut out the support reo underneath up to the area where it meets the boot seal (approx 2.2kg), but kept the centre reo from the boot latch to the leading edge of the bootlid.
Then, pinned the front down, and used the original latch to hold down the back, mainly because with the spoilers on using two pins for the back would be difficult, and I couldn't be stuffed tryin to source T-handle spring latches. The cable will still unlock it, but I'm using a spare key Jinkai'd into place permanently in the boot lock as without the torsion bar spring tension the boot doesn't really "pop" open.
** sorry for the highjack, just wanted to show Roy.....
soon mate, i have a friend coming around to upload a VY Commodore tune into it and adjust injector trim to suit the 42pounders. Also has to eliminate the anti-theft security stuff.
Once that is done it should be good to go. I have had a small set-back with the intake but should get it today. It still may require milling as the heads and block have been. Will trial fit it and mill if necessary. Obviously ensuring the port matching is perfect is important on a NA engine. Then some plumbing to the new fuel rails. In a perfect world that should happen this week-end, but we know how things go.
How are the car going?
Got it started yet? Still waiting for videos of the car running.. need some inspiration for my car... :banana:
