wow. i just read this thread from the VERY start to the end. amazing i take my hat off to you sir.
sorry to be a pain and ask but from what i gather if you don't plan on ripping everything apart, in a way its fairly straight forward? the wiring and exhaust of cause have their issues but other people deal with those problems and you encountered some problems when you went with the trumpets? i assume these would have been removed if you left the standard intake on?
The only thing i could bring it down to was the steering and brackets for mounting?
Without making everyone read through the whole thread (as amazing as it is) can you give a basic list on whats needed?
  • Replies 812
basically, if you were going to leave the engine standard and rego.
1) Fabricate engine mounts.
2) fit steering rack that will fit still encorporating power steer or run a manual rack. Rack ends to suit.
3) Transmission Crossmember
4) Tailshaft
5) Exhaust including modified extractors.
6) R33 clutch master cylinder bored one size oversize.
7) Radiator hoses (could use standard radiator) Thermo Fan
8) Throttle cable
9) Speed sensor compatibillity?
10) Misc plumbing e.g heater, booster, intake, air, steer. etc
11) Wiring
12) Modify fuel system (no return line) Reg intank.
these are the main points i can think of off the top of my head.
all conversions are similar, this one did not require things like crossmember, sump or trans tunnel mods which was good. and its a tidy fit, easy to change plugs and remove gearbox.
Thanks heaps for that the only other question i had and i might get pulled up here is that do you think the conversion (apart from the power outsings) would be relatively the same with just a 5ltr engine instead of the 5.7 im just weighing up all options here
Thanks heaps
Supercharged 6 would give less room I reckon. the V6 is not much more compact than the 8 and the you add the supercharger (and cooler if you want etc). also depends on the type of blower you use. and what 6 would you use? cause the old holden 6 is absolute crap. and buy the time you buy the 6, trans, blower etc it would probably cost more then the LS 5.7 and make less power. waste of time.
yeh i agree, the 5.0s are a cast iron boat anchor. 165kw. and not sure why you would condider a v6 conversion when you can bolt a turbo'd RB straight in.
Yeah, agreed on the V6 thing too. I hate the holden 6's, I think they're crap and I wouldn't waste my time on one.
Not sure what they weigh, but I dare say with all the ancillaries it'd be more than the LS1, or close enough to.
the eco-tech is still cast iron so it would be at least 60kg heavier, the alloytech in the vz onwards would be lighter.
ill see how the tremec goes next friday.
Going up to Unigroup in the morning to finish up the tune. Ill try to get more video of decent quality this time.
But what is a decent box that you can put behind the chevs. The ZF etc 6 spds are not exaclt slick things. I have found the motor i want for my car, but cant find a gearbox :down:
yeh, probably should keep both hands on the wheel instead of one out the window ya noob.....my arse hole got so tight when you were heading towards the concrete........rofl
Suuuuuummmmerrrrrnnaaaaaattttssss!!!!
lol!
Must have been a pleasant change for you?!
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
