  • Replies 812
ok, serviced the car yesterday, nothing special, just oil & filter. also dropped the rubbish nulon gearbox oil out and replaced it with some Repsol synthetic matic atf. Much better.
checked and adjusted the wheel alignment,
running 6 deg caster, 3 deg neg camber and 1.5mm toe out on front.
3 deg neg camber and 1.8mm toe in on rear.
will see how it goes. Bring on wakefield.
Had a great day at Wakefield, eventually got the tune sorted after datalogging a few laps, car was very lean in places so happy to get it sorted.
Diff is tired, needs a re-build, tyres also tired, so am i, but happy with the car.
managed to real off a few 1.08s in the last session which was very good.
hope to get diff done and some tyres for SAU track day.
yeh this one is, id speak to an engineer first.
Can i just ask somethign (and i'll be honest i haven't read the whole thread) but is this a track only car? As im looking to do an LS* V8 conversion on an R32 but am aiming for street use..
you may run into issues with the "you cant putting a V8 into a car under XXXXkg" rules
yeh not sure, ppl are putting vh45s in s13 silvias, whats a few extra cubes. whats a street trim 32 weigh?
Thankyou craved!!! 6.0L NA will do perfectly then!
Will have a detremental affect on turbo'ing it though....hmmm...oh well...as long as i can do it that's the main thing!
Is it true when you put a GM V8 in an R32 you have to for go the power steering?
They don't need turboing... It'll go like hell without one!
Think about it, take a VE Commodore with a 6.0L, what're they, 1.6T? Now drop 250KG... Throw a cam in, exhaust, tune done...
I'd have done it to mine except people want too much money!
there are also startermotor relocation kits available now which puts the starter on the other side which would solve all the issues. if your 32 goes 1350kg, you will be 450kg lighter than a VE, trust me, you dont need to turbo it. the car turns 3rd gear for fun. the torque is massive.
found a thread on sump extensions and baffeling, going to do this before next track day.
http://www.performanceforums.com/forums/sh....php?t=67247482
Oh really? sweet! that'd be better than not having powersteering lol
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
