What's going in that monster? Looks tough.
was going to be stroked windsor 351 - 427 with twin T04Z's but we have been approached by a certain manufacturer to build something else, so i'll let you know the minute its settled.
  • Replies 812
that looks like it was meant to be.....notice the fogger and solenoids. i like the way this boy thinks.
yeh baron, hoping it will all be worth it. will no soon enough.
lol. that is pretty cool. finally get that decent engine into a decent chassis. >_< I like it.
can't wait to see your thing rumbleing along stu. it will definitely rock.
haha, thanks for the warm welcome guys. my journey to the dark side is complete.
the guys in the drag section were getting confused when i started doing susupension & brake upgrades.
at least you guys understand whats going on.
Good to see the sig has been updated acordingly.
'Drain, I took him to watch some circuit racing on the weekend..........Conversion complete.
can we change the thread title to "drag setup/circuit setup conversion" ?
I see whatever you happen to have is contagious, Jase.
Shame. Stu was such a good bloke once upon a time, too!
:D
noooooooooo, have you seen him drive?
It's ok Adrian, there is still time to swap the auto back to a manual and since you haven't tubbed it yet, we can still get it to handle around a corner mate :ninja:
have been looking at intake manifolds for a while, the Harrop item was looking like the go
but after some research it was found that it would be difficult to adapt different length ram tubes to it as it was designed to fit in the commodore and this is not an option due to bonnet height etc. harrop was also very difficult to get in contact with as they do not return faxes or email. obviously dont want to sell any.
Came across another Australian made intake, well priced and is designed for interchanging ram tubes. i also know the guy who spins them up so can get a few sets made. once car is back on the ground and engine fitted im hoping to get one of these babies.
it depends on those that are doing stuff for me, example wiring, exhaust. i could have it together in a couple of days.
but still no cylinder heads. also waiting for a few front suspension bushes, so probably a month off.
when do you think you will have it ready to run?
recieved the best news ever today, my cylinder heads are ready. measured piston to cylinder head clearance and found we have to run a slightly thicker head gasket. cc'd the head and worked out comp will be around 11:1 if we deck 20thou of the head while still maintaining 80 thou piston to valve clearance. should have everything ready for assembly tomorro night.
Sounds like excellent news!
11:1 is a good compression ratio, a little higher than original...
Cant wait to see/hear a video of the engine roaring...
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
