have some nice Rays gt2s for sale that woul be sick on the silvia... :)
My front suspension arms arrived today, so should have everythig fitted and the car on the ground this week-end. was hoping to have the engine assembled and fitted but have had an issue with valve spring retainers, so unless a replacement set arrives 2morro, the engine will probably go in next week.
nice. they were a good buy. I was nearly going to grab them as a spare set for the silvia. then remembered I already have 3 sets of rims for the silvia.... :banana:
Edited by BezerkR32
  • Replies 812
... and additional front diff support bracket.
Charles do you mean the one that goes under the nose of the diff? If so, ditch it. Only the 32gtr ran this extra bracket, 33 and 34 don't use it, and neither do some big power cars I know of with theis cradle. You just need some large washers to protect the lower bush
Picked up heads after sorting out the valve train issue which ended up being a dodgy set of locks. Got a new set of Manley locks and all was sweet.
ARP head stud kit, MLS Felpro head gaskets, Comp Cam anti pump-up roller lifters, Comp Cam pushrods & Yella Terra rockers. I know that the pushrods may be a bit foreign to some people. lol. Also fitted stainless ARP exhaust manifold stud kit, as they were cheaper than GM.
Comp ended up at 10.9:1 after the deck machine, which is excellent as standard is 10:1
Will finish setting up the rocker pre-load and sit the engine in tomorro.
Looking nice!
I hope you didn't mount the heads the way you are about to in the bottom left picture... It shows your about to mount the head in the wrong direction... (Exhaust port to the intake side...) :domokun:
yeh, was going to try something different, but it wouldnt fit lol. you dont miss much. :(
Looking nice!
I hope you didn't mount the heads the way you are about to in the bottom left picture... It shows your about to mount the head in the wrong direction... (Exhaust port to the intake side...) ;)
some hot rod guys told me there was 10kw in doing it.
Starting to bang it all together, all going sweet, i guess thats the advantage in triall fitting everything first.
ill finish fitting radiator, and dummy up engine harness so electrician can start. can also start buying bends for the exhaust
Should get a mechanic to do it, Stu.
they are off our Commodore. They are 1&3/4" primary pipes into 3". they had to be modified to fit but only slightly.
Nice!
Not long now until you can start it...
From witch car does the headers come from? Pontiac GTO?
And what are the spec on the headers?
thanks Phunky, still a while off though. hoping to have it all done for powercruise, that will give me the oportunity to run everything in and sort out any teething problems before i track it.
Looking good! Can't wait to see this thing in action
BezerkR32, amen to ya brother, forget the haters lol, mine makes 340hp on a completely stock engine with a link g4 ecu, ive owned many an rb20det and a couple work rb25dets and I have to say I enjoy my new setup the most by far. I did manage to retain my power steering though, although its so incredibly tight as you can see from the pictures, that it initially wore a hole in the starter motor:S I have the car running now, just havent updated the thread. Cant wait to see some action footage lol.
Video
http://www.bebo.com/FlashBox.jsp?FlashBoxId=8060454510
Build Thread
http://southernskylines.com/phpBB3/viewtop...f=24&t=2359
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
