  • Replies 812
yeh lol. would have loved it, but sounds like a not so amatuerish event anymore, but cant miss F1.
Boz's track day is my goal.
yeah a net is all you need, and only on the drivers window.
hope its coming along ok....I think you might miss superlap...
Back from F1 and all syched to get this car going.
Up at the exhaust shop today, half was already done. I mounted the shielding
and the mounting brackets while Pottsy finished the last bend and started on the mounts.
Just the tips to go, some paint then all done. There was some cranky Chevs down at Melbourne.
Got the blood pumping.
Do the pipes join in that middle bend? i.e. exhaust gasses from each bank meet? or do they just meet and touch foreskins?
and Dick, get in line :sick:
it's an x-pipe. gas can flow between the two banks. :laugh:
interesting.
Its an ex-HRT trick that was only discovered by the other teams after Craig Lowndes put the car on its roof for all to see what they had designed.
see pic
Edited by DiRTgarage
Yeh its a pretty common thing these days. Its for balance Jas. and yeh they sound shit without them. The guy who designed the mufflers also gave me dimentions for the merged area in the X pipe and the reducer behind the collectors.
All these dimensions came from some software programme he had after entering some engine specs, ie bore, stroke, comp, estimated peak rpm, cam specs etc. the 2 1/2" reducer behind the collector eliminates the doughy dead spot you sometimes get down low by speading up the gas flow again as it cools resulting in scavenging the dead gas out of the cylinders leaving area for the new air fuel mixture to enter.
Sounds like i know what im talking about hey, but the scavenging thing was explained to me today in a way that i understood. It is also said that the area of the X pipe controlls the torque band. Its all a bit more complicated in a atmo engine thats for sure. But all these things combined are supposed to make for a good efficient system.
Pottsy put a tube in as to measure back pressure, appatently anything over 1.5psi at 5000rpm is getting excessive and can result in power loss.
He also decided that two 3" outlets on each side will look trick so just waiting for some collectors and it will be done.
Fuel rails are well under way also, have managed to find 15mm. Just hope its enough.
My clubbie runs an X-pipe system too
yeh i did see that, i hope its ready but thats only a month away, im waiting for my membership stuff to come back and then ill send off for the cams license. Ill give it a good shake but might be a late enterant.
looks good stu. SAU trackday is the place to debut it....plenty of laps to be had and no pressure
this build is so cool, love it... can't wait to hear that thing chugging away, and the looks on people faces when a 32 rolls past with a monster V8 burble... the exhaust and intake are giving me the 'orn!
you will post some video once its running... pretty please!
finally figured out the sway bar issue after some lenghty phone calls by the Auto 1 boys to Whiteline and red-Ranger and found a VL commodore turbo brace is the one to use. just have to make end plates and reverse the way it runs so across the front of the engine instead of around the back.
dont you love public holidays. Got a bit done, fabricated strut brace end-plates, painted them and mounted the brace. Also port matched the intake manifold and bolted it down for good.
Ill try to get a bit more done this week-end.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
