wow. i just read this thread from the VERY start to the end. amazing i take my hat off to you sir.
sorry to be a pain and ask but from what i gather if you don't plan on ripping everything apart, in a way its fairly straight forward? the wiring and exhaust of cause have their issues but other people deal with those problems and you encountered some problems when you went with the trumpets? i assume these would have been removed if you left the standard intake on?
The only thing i could bring it down to was the steering and brackets for mounting?
Without making everyone read through the whole thread (as amazing as it is) can you give a basic list on whats needed?
  • Replies 812
basically, if you were going to leave the engine standard and rego.
1) Fabricate engine mounts.
2) fit steering rack that will fit still encorporating power steer or run a manual rack. Rack ends to suit.
3) Transmission Crossmember
4) Tailshaft
5) Exhaust including modified extractors.
6) R33 clutch master cylinder bored one size oversize.
7) Radiator hoses (could use standard radiator) Thermo Fan
8) Throttle cable
9) Speed sensor compatibillity?
10) Misc plumbing e.g heater, booster, intake, air, steer. etc
11) Wiring
12) Modify fuel system (no return line) Reg intank.
these are the main points i can think of off the top of my head.
all conversions are similar, this one did not require things like crossmember, sump or trans tunnel mods which was good. and its a tidy fit, easy to change plugs and remove gearbox.
Thanks heaps for that the only other question i had and i might get pulled up here is that do you think the conversion (apart from the power outsings) would be relatively the same with just a 5ltr engine instead of the 5.7 im just weighing up all options here
Thanks heaps
Supercharged 6 would give less room I reckon. the V6 is not much more compact than the 8 and the you add the supercharger (and cooler if you want etc). also depends on the type of blower you use. and what 6 would you use? cause the old holden 6 is absolute crap. and buy the time you buy the 6, trans, blower etc it would probably cost more then the LS 5.7 and make less power. waste of time.
yeh i agree, the 5.0s are a cast iron boat anchor. 165kw. and not sure why you would condider a v6 conversion when you can bolt a turbo'd RB straight in.
Yeah, agreed on the V6 thing too. I hate the holden 6's, I think they're crap and I wouldn't waste my time on one.
Not sure what they weigh, but I dare say with all the ancillaries it'd be more than the LS1, or close enough to.
the eco-tech is still cast iron so it would be at least 60kg heavier, the alloytech in the vz onwards would be lighter.
ill see how the tremec goes next friday.
Going up to Unigroup in the morning to finish up the tune. Ill try to get more video of decent quality this time.
But what is a decent box that you can put behind the chevs. The ZF etc 6 spds are not exaclt slick things. I have found the motor i want for my car, but cant find a gearbox :down:
yeh, probably should keep both hands on the wheel instead of one out the window ya noob.....my arse hole got so tight when you were heading towards the concrete........rofl
Suuuuuummmmerrrrrnnaaaaaattttssss!!!!
lol!
Must have been a pleasant change for you?!
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
