  • Replies 812
not sure of the break-up as i bought the lot as a package. total was $3800
Selby's bar, noltec bushes, bilsten shocks with eibach springs - I assume they are simply stock, powdercoated arms - is that right?
any idea what the coilovers are worth roughly?
thought i saw you cruise past, we were sexying here up for possible photo shoot on tuesday.
it sounds the sex, i got a peak at it drivin past ur place today :thumbsup: u need to go out terrorising one night haha
yeh they are standard arms. Just fitted bush kits in each end. Can get over 3deg neg on the rear which is way to much anyway and at the time i got them the new adjustable arms were still in the developement stage and were proving unreliable, and the standard arms are strong.
cool, thanks. so they are stock suspension arms then?
yeh, probably should keep both hands on the wheel instead of one out the window ya noob.....my arse hole got so tight when you were heading towards the concrete........rofl
car sounds and looks sweet! driver should stick to drag racing I think.... :thumbsup: teehee.
yeh, all set..........i think......getting a bit nervous now actually.
have to swing a spaner over it 2moro and change the running in oil and check other levels but thats about it.
Lookin good Stu!! All good to go for Friday i take it?
was planning to do the above things today after the photo shoot for Boost Magazine but after being turned away from the local kart track we made our way to the local Nissan dealership to shoot. We shot pretty much everything we had too when the manager came out and told us we couldnt use anything as the dealership could not be affiliated with an import. 3 hours wasted. Was lucky enough to be allowed to do the shoot at local wrecking yard (Dapto Pick A Part) who were more than happy to have us there. 2rismo may be able to shed some light on what issue it could be in.
fyck that sucks. probably would have been wise for the magazine to ask their permission before spending 3 hours using someone's commercial premises as a background though... :(
hopefully you got some good shots though. :happy:
nah Baron we were told it was all good, then pulled the pin. we were actually on the lot with all the cars. it was kinda cool, but i think it worked out for the best as the photographer was happy with the second lot of shots.
Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :(
never mind, we love Pick A Part in Hamelton St Dapto.
Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :bunny:
what bastards! yeah I did think it strange for the guys not to have tee-d something up before hand. bad assumption on my part. >_<
what clowns. give permission then take it back. not to mention the fact that photo shoots like that do nothing at all to hurt their brand. they should look at it as free advertising. do they want to endear themselves to young, hip demographics that have disposable income or not? looks like not. very close minded. and typical of the imports are evil attitude yet they are happy to make money flogging us parts for them...
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
