yeh, think they are heavy. i know yella terra re-designed them so would be interesting to see the new ones.
i will be putting a set of Harland Sharp rockers this time though.
Any idea what the issue is with the roller arms? too heavy and causing valve float / bounce?
  • Replies 812
got through a bit of work this week, removed rear boot latch and fitted some bonett pins on the boot lid to make it easier to access the fueltank and eliminate the risk of loosing the key and not being able to open the boot.
Purchased a GT style rear wing, 1500 wide and sits just over 300 off the boot lid. Great fathers day present, thanks girls.
have began lowering the drivers seat which we should finish tonight. Also going to lower the fuel tank to drop the centre of gravity as it was advised this could aid in helping with handling in the rear of the car.
Still waiting for the front bumper. Might give the air ducting/engine cover a crack on the week-end.
Your build is mint and i didnt want to be critical of an awesome build, but i was left wondering why you threw the fuel cell up high in the boot. Throw back in the std jobbie, or GTR as i am told they are plastic and lighter, ...or better yet make up a 30L smaller alloy jobbie that sits under the car but in front of the rear axles...perfection.
I am reading all these build threads whilst stuck in a hotel room and so keen to ge tback to Aus and getting something going
i guess i did it this way as the tanks are cheap and it was easy to modify to run the internal pumps and because ive set up to many fuel systems on drag cars lol. If i run a standard tank i would have to run a surge and i just wanted to keep it simple. My setup only runs a feed, pressure is regulated at the tank.
Ill drop the tank into the wheel well and the sump will hang through. Its minimal work to do this and i wont have to re-plumb anything.
i
OK, the wing is on......and im not sure about it. maybe it will grow on me but at the moment i think its ricey, when i see it all i can think of is honda civics or mitsubishi lancers. i hope it gives the downforce it looks like it should or its going to get the ol heave ho. Anyway can always sell it to a drifter lol.....which makes me wonder why they have wings anyway.
im still waiting for Vin Diesel to climb out of it....
The wing is glass with a wrap. The uprights are cnc machined alloy and pretty serious though and it has large endplates.
i bought it second hand over the net. Dont know who makes it....could even be a custom job but not sure.
It looks alright Stu, Is it carbon?
also any idea who makes it / sells it?
Started on the air dam today. Used a fibreglass bonnet outer skin, marked it out and slowly got it to sit around the intake.
still have to glass up the sides and fit mounting brackets but you can get the general idea...
ha ha, driven a commodore lately? with the amount of off the shelf parts and interchangeable parts available for a Nissan, let alone the body shape of the R32 which is small, and arguably the best ever made, the combination was good. And im not sure what a Commodore has to do with it, if i had the coin i would have bought a Vet.
The thing is i always wanted the Skyline, the engine popped up by chance. Ive owned one taxi and ill never go back....
After all this man why did you put a v8 into your 32??? shoulda just bought a commodore if u want a v8!
got intake dam back from fibreglasser today and he had done a top job, we trial fitted it and it was near perfect.
finished trimming the sides down and fitting dzus fasteners tonight. It will do for sunday, ill get it painted after that.
also fitted passenger seat and harness for the track day.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
