  • Replies 812
f**k this thing is loud on the inside.
don't know how happy stu was with it....but I was lucky enough to do some laps in the passenger seat and:
a. it goes like stink
b. handles pretty good and
c. stu seems to handle a steering wheel pretty good.
the dino-line is a unusual setup but its working damn well.
thanks mate, made a small error with uncle Duncan in the car like missing turn 1 but other than that the car was much better behaved. was much more confident under braking.
have some light throttle tuning to sort out and a gearbox selector issue but other than that very happy.
car held its own in a staight line against a few cars boasting 70kwatw more, but the weight factor would have a lot to do with it. wet weather sessions were interesting.....but car was solid once it dried out.
Some good Superlap type cars in the new issue of Zoom Magazine, boys and girls. Tilton Interiors Evo, a psycho red Supra (SUPRAT) and some great photography from the event.
There's also a full feature on the Roger Clark Motorsport (RCM) Gobstopper WRX and Stu's awesome LS1 R32.
Enjoy :-)
I knew there was a build thread around here somewhere and i've only just found it now.
Seeing this animal in the metal idling at a standing still and running on the track is a sight to behold. It's something that you just can't visualise mentally because it has to be seen in person.
Some shots I snapped of it running at Oran Park at the SAUNSW track day. :)
cant run any forced induction over 3000cc engine capacity in sports sedan and maximum of 6000cc aspirated.
ill stroke this engine when i freshen it up which hopefully wont be in the near future. car is a handful now with 300kw, cant imagine another 100kw.
currently in the process of getting car log-booked, just finishing off a few little odds and ends like remote battery isolator cable and sealing rear parcel tray. Getting inspected this week-end.
Thanks for the great words and pictures Xmetal. love the shot at the back of the track....
ls1 is an import. 5.0L V8 was holdens last V8 motor castine block.
if u knew something about those motors u can strap a snail on and get easy 400rwkw with stock internals..no shit motor!
Car all log-booked and have sent away for my L2S liscence.
Looking forward to show-n-shine in december, as i dont think ill get it out for a meeting before the end of the year. Discovered the tach-recall button and got a shock to see highest recorded rpm, probably shouldnt do that too often.
  • 2 months later...
reverse gear repaired and gearbox back in the car, looking forward to next track day which will probably be at wakie and then powercruise.
weighed car and it went 1193kg which is a little heavier than i thought but still lite enough.
Good on you man you should be proud of yourself for trying this . i have a porsche carrera 2 with an LS1 in it, with great help from others , the LS1 motor is lighter than the stock 6 with turbos and generates more power . Good luck
Do show, where is your build thread?
  • 2 months later...
hey guys, long time since any updates. Running the car on Anzac day to finish tune on the track to tidy up some light throttle issues. Also trying some new wheel alignment specs. Hope to see some of you there.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
