Ok Mohammed ur back on the list as confirmed..will ur girlfriend be comong allong with u too now!! :closedeyes:
as for info on the South East pre-meet i believe all the info is in the thread below:
http://www.skylinesaustralia.com/forums/in...t&p=3408212
...so once again, list updatd
Edited by DNGRUS
  • Replies 131
Posted Images
No worries Ilyas, hopefully you and your R33 can make it...
If not pass this message onto Serife for me, tell her Ferah said for her to still come in her integra :)
Hey Ferah yeh sorry bout that, yeh ill pass it on,i might actually give her my car n she can cum with that. If you want give her a call before sunday.
Hahaa ok ill probly see her either 2nyt or 2mro 4 sure @ work...
Thnxx Ilyas
What time is the SE Pre-Meet? Can anyone confirm please. I can't seem to find it in this thread. I know the location, just need time.
Cheers
Moe
pm ashneel he'll give u all the details or check the link out at the top of thispage. fearh posted it up.
Cheers
Moe
Hey Moe, here is a quote from Ashneel in regards to the south east preemeet @ Brandon Park
9:15sh and we leave 9:45
:P
ALLURE Girls would like to thank those who attended the ALLURE Mini Meet/ Mini Cruise!
it was a great day a few hick-ups but for our first cruise it went pretty good... Great Weather and a great group of people!
Pics will be posted soon!
Cheers
ALLURE GIRLS
Big Thanks to the Allure Car Club for holding such a great cruise!.
Weather was nice, and there was a decent turnout of cars.
Nice to meet a few new faces, and to let my gtr stretch its legs on those awesome roads.
Trentham Falls was a good stop, especially on a hot day like it was yersterday.
Can't wait for the next one :P
Anywayz.. here are a few snaps i took.
im glad u all enjoyed it..!
I know i did! Everyone who came, THANK U! You were all so freindly and was a GREAT pleasure to meet u all..!
Will see u all at the next event and hope to cruise with u all soon
-Ferah
(oh btw - ill have my piks up hopefully 2mro!)
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
