  • Replies 58
My car will officially not be ready :blush:
Mav you have a chance this year :), But there are alot of new cars in the club this year that look awesome!!
On the other hand i have a booking for a level 2 or 3 car detail with FINAL INSPECTION for the 7/12/07 (the Friday before the BBQ), as my car will probably still not have an engine. I am offering this booking to anyone that wants to take my place, otherwise i will simply just call and cancel. The swap will require Damein's (Final Inspection) approval, but i can not see this as a problem. Let me know ASAP, as i do not want to fark Damein around..
My mobile: 0427 076490.
Damian's work will guarantee you of VICTORY!!! :)
That's why i booked it 2 months in advance, the day before the Show n' Shine :)
But the car will not be ready in time :(
ANYWAY, BOOKING ALREADY TAKEN BY ANOTHER SAU MEMBER.
How many 4 doors will actually attend? We probably need 8-10 to seriously consider another category.
It'll be just like a few years back when we ordered a 'Best R31' trophie. Took us months to palm that little sucker off.
That's right Ash no one likes you :)
My datsun gets 40 rods to the hogs head and that's the way I likes it!
Remind me to fill the coal and asbestos chambers.
heh coal & asbestos.... at least yours runs on something...
i may have to cut a hole in the floor and pedal my way down there... flintstones styles
1st post has been updated with the below prize information:
Prizes and Awards:
Trophies and a $240 Centreline Suspension voucher (valid for parts and labour) will be awarded for "Best in Show" in the following main categories:
• Godzilla class (32, 33, 34 GT-R) - Best overall GTR
• Godzuki class (31, 32, 33, 34 GTS/GTT) - Best overall GTS/GTT
• WRC class (WRX, Evo)
• Dorifto class (Silvia platform)
• Intruder class (other)
& there will also be trophies, a 12 month suscription to Unique Cars (value $80) and an SAU polo shirt awarded to the winner each of the below:
• Godzilla class (32, 33, 34 GT-R) - one each for 32GTR, 33GTR, 34 GTR
• Godzuki class (31, 32, 33, 34 GTS/GTT) - one each for 31, 32, 33, 34 GTS/GTT
FYI - All trophies/prizes will be presented at the December General Meeting (18/12).
Interested in coming to this event, I just need to find out if paint ball is happening this weekend or not. And I'm coming alone so that always makes things harder :no:
Oh, can someone please fix the spelling of "stupidty" in the advertisement? :wub:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
