General Meeting - Tuesday 16 October
It's SAU Vic Social Meeting time. That's right, Beer, Food, Beer, Cars, Beer and laughs!
These social meetings are divided into two parts, the first if your hungry is a meal from the bistro and a chance to have a chat with other members then the second is a short informal meeting.
We use these meetings to give quick rundowns on past events with video's, pictures and stories etc, to address pressing matters, tell members what's happening behind the scenes and for discussion on upcoming events. It's all pretty relaxed and fun. This is a great opportunity for those of you who don't know too many members to come down and mix as new faces are always welcomed.
Time - 8:00pm (Dinner from 7:00ish)
Date - Tuesday 16 October 2007
Location - Bell's Hotel, 157 Moray St, South Melbourne (Cnr Moray St & Coventry
St Melways Ref - 57, G1) - see map below
Note - This Pub is family friendly with an area set aside for us. There is plenty of seating (tables and chairs) and meals for all.
Who is welcome - Everyone!
MERCHANDISE
- ALL Merchandise will be available for sale at this meeting. Come see me.
- This includes a new delivery of SAU Polo Shirts. So we now have both colours in all sizes.
EVENT REVIEWS
- Morwell
- Drag Day @ Heathcote
UPCOMING EVENT DISCUSSION
- NSW Road Trip
- Annual Show N Shine / Xmas Party
WHAT ELSE WILL BE HAPPENING:
Guest Speaker -
Chris Muscat from Centreline Suspension will be giving us a run down on all things suspension.
Presentation -
We will present trophies and prizes from the Drag Day at this meeting.
James' Car of the Month -
From Lada's to Lambo's - what will we see for Show N Tell this month (let's face it - chances are 'something' will pop up though) :(
Hope to see you all there.
Map:
https://www.sau.com.au/forums/topic/187923-general-meeting-tuesday-16-october/
From Lada's to Lambo's - what will we see for Show N Tell this month (let's face it - chances are 'something' will pop up though) ;)
The longer James snubs his adoring minions, the more unlikely it becomes he will grace us with anything better than a Lada (he could always try for a Skoda)
An awesome speaker is lined up for October!!
Chris Muscat from Centreline Suspension.. he's also:
1990 Club Car Champion.
1st in Class 1995 Bathurst 12hr.
1st team Winton 24hr 1992.
2002 Victorian Sports Sedan Champion.
and probably more stuff I don't know about ;)
He'll be chatting about everything suspension - track and drift setup and what you can do to improve handling and the like.
You could just barrage him with a bunch of questions about his racing days though, caus that's always entertaining! :(
He gives advice at track days all the time, so it should be good :D
Come listen to Pete talk about his new wheels....The tale of high adventure!. How he hunted them down and had to slay dragons to get them. To having to fight hordes of people to get them out of the paintshop. To only have to kill the people who fitted them because they didnt use cotton gloves...cant wait to hear all about it....down a few schooners then piss on your new wheels :spank:
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
