Hi, new here, was hoping someone has done a rb25 into a r31 conversion
I have a rb25neo non-turbo with a tiptronic auto
Want to upgrade my aussie r31 ti,
Does anyone know if the engine mounts would fit?
Also, would the gearbox fit, I was hoping I wouldn't have to change the tailshaft.
Any other info on this conversion would also help heaps,
For instance, radiator hosing, afm, wiring and where to get the ecu and the transmition computer
Thanking all of you in advance
https://www.sau.com.au/forums/topic/187942-rb25neo-into-r31-conversion/
motor will bolt straight in, not 100% on the gearbox, but it should be very close if it doesnt bolt stright up.
I dont know about the radiator or tailshaft spline.
I'm thinkin that an NA rb25 wouldnt be much of an upgrade to an rb30 if any.
but overall, it would be an easy conversion.
cheers, Jason
Rb25det has a round engine mount and the rest of the rbs are square/rectangular dont know if this will affect fitting but your gearbox crossmember mounts will be slightly out so you will have to modify your original crossmember and as for the tailshaft all you have to do is have an r33 yoke fitted to the front of the tailshaft so it will go into the gearbox and it will bolt straight up (this is what i had to do to mine but its a 5sp 33 box not 100% about an auto)
Hope this helps
it will bolt stright in, if you have an auto r31, tail shaft is perfect
use the rb25de mounting bracket with the r31 engine mount...
i put an auto r33 rb25det into my GXE.. PM me and i'll give you the details of the bloke who did the wiring for mine..
he might be anoyed cause you stole his forum name LOL
you send him your engine loom and the loom from the r31 and he will send you back one that will mate your engine to the car. you use the r31 plug at the AFM for power to the ECU & injectors for the rb25.
he has a HR31 with the NEO rb25det running the Triptronic auto box and the steering wheel controls...
Edited by rsx84
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
