  • Replies 241
Posted Images
been trying to find some pics for you
but Im over it
look up a drift team in Japan called Murder they have done r32 wt 34 front
33 wt 34 front 32 with 33 rear
there 32 with 34 front looks much better than the bee r car imo and was done back yard style
http://www.geocities.co.jp/MotorCity-Pit/3155/
I got this close but I think its a very big team and this is them from another area
just scanned the art
there's also a green R32 sedan with an R34 GTR frontend done by a drift crew... the build article is in Skyline mag (yes there's a dedicated magazine for skylines, and another for GTRs)... i'll scan it up.
r32's with 34 conversions would be cool in canada where no one has an R34 (well legally anyways) but you'll find that outside of there it'll mostly be on drift cars and other cars which are generally trashed about and have had a frontal crunch.
here is a Bee-r B324R here in Canada.
In my opinion the car looks terrible.
I cannot get over how bad the front bumper looks, and the gas door isnt flush... then using the r32 taillights just kills the impression.
i am extremely happy that i didnt settle for the bee-r look, and went my own direction.
regarding the pink gtr in the above post by 1400r
i like how the front end looks completely stock of an gtr look, but HATE the Uras style sideskirts and rear bumper.
I hope my car will be one of a kind and known worldwide;)
  • 4 weeks later...
Its Getting there :)
Thought you said the rear was getting done a while ago/ already done. and you were getting it moulded.
no i said the front fenders were getting a mold of it so i can sell the conversion fenders, and WHEN the rear gets complete, i will make a mold of that aswell before it gets painted so i can manufacture the full kit once complete.
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
Anymore progress with this project or has it come to a stop.
Well im paying for this project to be converted.. its not in my hands...
I went there today to take some UPDATE photos for the world:P
When I said rust free GTR... i never thought it ment DUST free too!! wow.. she is a clean one.
oviously the r34 sheet metal needs some more detailed trimming...
rear panel behind bumper
Old quarter panels for sale... 200CDN/side lots of life left
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
