  • Replies 241
Posted Images
Hey Hows it going man, I live in canada, well Quebec, I have a R32 GTR and I'm planning on doing the same thing as you but different, what I'm asking is what website or provider did you use to get your parts, because I have a bunch of Japanese and American Sites, but the trunk is carbon fiber and so is the hood and stuff, and also the lights arn't included. I have a gerneral Idea of what I'm going to do with the front, but it's the back i'm worried about, I have to cut part of the back to get the trunk to fit good. Anyways if you can give me your provider via pm or on this post would be great.
What I need to know is where you got your
R34 GTR OEM Front Marker Lights(Flashers Yellow Light?)
R34 GTR OEM Rear Tailllights
R34 GTR OEM Trunk
R34 GTR OEM Trunk brake light
R34 GTR OEM Metal behind taillights Panel
R34 GTR OEM Back up Lights
R34 GTR OEM Aluminum Hood
R34 GTR OEM non-xenon Headlights
Thanks again man I hope you can answer me, cuz I'm tired of googleing and stuff to find a provider, thanks
Shawn
one short word, NISSAN
.. i ordered it all through my local Nissan Dealership. I just had to find all the part numbers myself with my Nissan FAST program i have on my laptop.
Any update since? Very nice conversion. I am currently doing an entire S15 conversion on my S14, the work entailed is quite similar.
give me one sec, im just uploading more pics.
so far, the rear end is pretty much done, now the sideskirts have to be custom molded, and thats about it. trunk latch assembly is being shipped... its one damn big job. not for the faint of heart, or someone with a limited budget, thats for sure.
I know it isnt much of a big deal in Aussie, but Here in Canada, the R34 isnt legal, and isnt on the street. This will be one of the only cars in Canada that resembles an R34 At all... should fool alot of ppl at least on the highway and passing by.
worth every penny :thanks:
looks good.
The rear is much lower than a real R34, as is the R33 rear.
This is taking a very long time, must be killing you. do you spend every day on it? or is it a side project?
looks good.
I think the rear was level with the body line... the r32 is more straight so we had to contour the rear to match.
the r34's body line starts rising near the side mirror and goes higher and higher till the end, but using that shape wouldnt suit on the r32, cause the tail end would start to point on an upwards angle and look even worse.
believe me, i want this done asap, but not 100% a priority
Yeah. Downside of a 34 anyways, but it gives it its distinct look, thats why the 33 to 34 looks different to a real one cause the body all over is lower from the roof down to the rear.
Ah well, good luck (Y)
thanks, its not really luck, just time.
Coming along nicely,
Panel shops rarely do their best work under the pump in my experience, and if you're spending that amount of dough you'd want them to take their time and do the job properly!
well the price would probably be alot more if I told them to hurry up, and focus this as their only project until its done. but bumps in the road happen, and things go on a standstill while new parts must be ordered to make the install as seemless and OEM as possible.
my new website will be online once the car is completed WWW.MWR34.COM
it will be the home of the complete build gallery, the photoshoot gallery, details of car, also this car will be for sale.
And future build plans for your custom-made MWR34 will be available. lets hope this turns out nice.
  • 3 weeks later...
Tell me what you think..
I took the dash from my Bayside Blue crashed parts car, and now making my own custom modified / fiberglass'd Dash board.
From the pictures I hope you can see where im going with it.
DAY 1
Dash cleaned and degreased
closer
guidelines and Center vent safely removed
closer
BAM!!! Cut off
Upper cluster tray
Back together
general look will be like this:
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
