Hi Guys,
well my stock r32 turbo is on its last legs due to the fact that any + boost applied causes a sound which could only be explained as a the sphincter of the universe stuck in a blender. I have purchased a s2 r33 turbo from a forum member and I’m going to get it put in ASAP. I just have a couple of questions as I need to make sure I don’t forget to buy anything ect. Basically I’m on a very strict budget so I really can’t make any mistakes
That’s where you guys come in J
My current setup:
r32 gts-t 93,000ks manual
Rb20det
gtr fuel pump
serviced stock injectors
new plugs
pod
3” front pipe back exhaust
boost gauge
a/f gauge
parts to go on
3” split dump pipe
flying fuel adjustable pressure regulator
FMIC
Q1
I have a cold starting issue which causes the car to take 5-6 tried before it starts and I have to flutter the accelerator pedal to get it to lump over else it won’t start. Once the car starts and revs over 2000rpm it idles and drives fine I believe it’s due to low fuel pressure so I have purchased a flying adjustable fuel pressure regulator with gauge so I can check it out and troubleshoot further. Do you think it is fuel pressure?????
Q2
I’m not doing to turbo swap myself so I wonder about cost of install as I need to get the dump put on and the FPR install. (I know the FPR is easy to install but the stock reg screws are threaded and I can’t think of a way to get it off.) Any ideas?????
Q3
if I did put the reg on myself what if its set to high can it stuff or blow my engine trying to start it??
Thanks guys hope there is enough info for you
please help
  ashr32 said:
Q2
Q3
please help
Q2 should be about 6 hours to do the install
Q3 you really need to get a fuel pressure gauge and set it correctly otherwise you risk flooding the motor or starving it, both of which are not good.
Where can I get a turbo like that from?!
I'm not an expert but here's my ideas:
1) I have a similar problem with cold starting. It wants to stall, though i tap the throttle and it's fine. Seems to be lack of fuel pressure i reckon too. Don't know if the pressure regulator will help, ask someone to put it on if you're not 100% confident. Maybe your fuel filter is dirty and slows everything down.
2) The turbo install, well far as i know most workshops are about $60-$80 an hour. Might end up costing you 3-$400 approx to get it put on. Get some quotes. Go for quality work first (duh), not dirt cheap. Yeh get them to add the dump while you're there. It's not a big thing to screw it to the turbo and saves you the work for a little extra cash.
3) Same as 1. I don't have one so i'm not sure about how to set it, so make sure it's done right either by you or a mechanic.
You probably already know, but stock R33 turbos aren't strong so keep it to 11-12psi max.
Good luck mate. Enjoy the extra power :thumbsup:
turbo, dump, o2 sensor all at once.
Call nissco on 9761 4743, say ryan sent you. I go there coz the work is top notch and the service is awesome.
GKtech dump pipe is ~100$
-Ryan
thanks for the info guys, awesome as usual. im gunna take it into a performance shop and get there ideas on the situation aswell. its just that from my experience you guys know more that any shop i have taken the car to seriously.
fpr's should be set to 1:1 by default and once its put in it can then be modified right??? i just need the guage side if things so i can see the pressure drop/raise. as the injectors/fuel pump and filter have been done i can only think that fuel is len its does start eaking back to the tank causing me to have to pump the pedal to get it to started.
even when it does start it does so very slowly and i can hear each cylinder firing for 3 seconds or so then it picks up and is fine. sometimes i hear a popping sound coming from the engine in that 3 second period as well. whats that??????
skylines, so many problems so little money
man i must love my car to put up with this.
ok,
you havent mentioned whether the turbo comes with the compressor outlet elbow or not. You WILL need this part.
Other than that it is just gaskets and putting a nipple somewhere on the intercooler piping for the wastegate actuator.
The rest bolts up turbo wise.
My car does a similar thing when cold starting but it is because it runs rich. get someone to start the car for you when it is cold
while you are looking at the exhaust. when it first fires up check to see if it blows any smoke
Q1 - Buying the FPR was prolly a little premature. The idle control valve, or stepper, should open sufficiently to start the car. If you need to feather the throttle; maybe give it a clean. Check the ECU for error codes, clean AFM etc etc. Rape the forums search button for others experiances.
Q2 - Use a penetrator on the screw and let soak... then use some multi grips around the outside of it. Try a "ezi out" if not previous doesn't work. Set the base to 43-45psi fuel pressure.
Q3 - Setting the pressure too high or too low will stop it from starting, but it wont blow up. Setting the pressure too high and running it for a long time could coke your combustion chamber. Setting the pressure too low and running it could blow your motor up.
If you have some basic tools, patience and are able to use the search button on this forum, you should be able to save your self the labour by fitting turbo and dump. I would leave the FPR unless your getting the thing tuned / chipped in the future.
Edited by GeeTR
  ashr32 said:
hi guys this is a link to pics of the turbo i got http://members.dodo.com.au/n0ob
does this have a compressor outlet elbow????
Nope. The middle picture from your link. The silver side on the left is the compressor cover, containing the compressor wheel. The bit pointing down, is the outlet, and a flanged elbow would bolt on there i would assume.
Edited by GeeTR
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
