Hi Guys,
well my stock r32 turbo is on its last legs due to the fact that any + boost applied causes a sound which could only be explained as a the sphincter of the universe stuck in a blender. I have purchased a s2 r33 turbo from a forum member and I’m going to get it put in ASAP. I just have a couple of questions as I need to make sure I don’t forget to buy anything ect. Basically I’m on a very strict budget so I really can’t make any mistakes
That’s where you guys come in J
My current setup:
r32 gts-t 93,000ks manual
Rb20det
gtr fuel pump
serviced stock injectors
new plugs
pod
3” front pipe back exhaust
boost gauge
a/f gauge
parts to go on
3” split dump pipe
flying fuel adjustable pressure regulator
FMIC
Q1
I have a cold starting issue which causes the car to take 5-6 tried before it starts and I have to flutter the accelerator pedal to get it to lump over else it won’t start. Once the car starts and revs over 2000rpm it idles and drives fine I believe it’s due to low fuel pressure so I have purchased a flying adjustable fuel pressure regulator with gauge so I can check it out and troubleshoot further. Do you think it is fuel pressure?????
Q2
I’m not doing to turbo swap myself so I wonder about cost of install as I need to get the dump put on and the FPR install. (I know the FPR is easy to install but the stock reg screws are threaded and I can’t think of a way to get it off.) Any ideas?????
Q3
if I did put the reg on myself what if its set to high can it stuff or blow my engine trying to start it??
Thanks guys hope there is enough info for you
please help
Q2
Q3
please help
Q2 should be about 6 hours to do the install
Q3 you really need to get a fuel pressure gauge and set it correctly otherwise you risk flooding the motor or starving it, both of which are not good.
Where can I get a turbo like that from?!
I'm not an expert but here's my ideas:
1) I have a similar problem with cold starting. It wants to stall, though i tap the throttle and it's fine. Seems to be lack of fuel pressure i reckon too. Don't know if the pressure regulator will help, ask someone to put it on if you're not 100% confident. Maybe your fuel filter is dirty and slows everything down.
2) The turbo install, well far as i know most workshops are about $60-$80 an hour. Might end up costing you 3-$400 approx to get it put on. Get some quotes. Go for quality work first (duh), not dirt cheap. Yeh get them to add the dump while you're there. It's not a big thing to screw it to the turbo and saves you the work for a little extra cash.
3) Same as 1. I don't have one so i'm not sure about how to set it, so make sure it's done right either by you or a mechanic.
You probably already know, but stock R33 turbos aren't strong so keep it to 11-12psi max.
Good luck mate. Enjoy the extra power :thumbsup:
turbo, dump, o2 sensor all at once.
Call nissco on 9761 4743, say ryan sent you. I go there coz the work is top notch and the service is awesome.
GKtech dump pipe is ~100$
-Ryan
thanks for the info guys, awesome as usual. im gunna take it into a performance shop and get there ideas on the situation aswell. its just that from my experience you guys know more that any shop i have taken the car to seriously.
fpr's should be set to 1:1 by default and once its put in it can then be modified right??? i just need the guage side if things so i can see the pressure drop/raise. as the injectors/fuel pump and filter have been done i can only think that fuel is len its does start eaking back to the tank causing me to have to pump the pedal to get it to started.
even when it does start it does so very slowly and i can hear each cylinder firing for 3 seconds or so then it picks up and is fine. sometimes i hear a popping sound coming from the engine in that 3 second period as well. whats that??????
skylines, so many problems so little money
man i must love my car to put up with this.
ok,
you havent mentioned whether the turbo comes with the compressor outlet elbow or not. You WILL need this part.
Other than that it is just gaskets and putting a nipple somewhere on the intercooler piping for the wastegate actuator.
The rest bolts up turbo wise.
My car does a similar thing when cold starting but it is because it runs rich. get someone to start the car for you when it is cold
while you are looking at the exhaust. when it first fires up check to see if it blows any smoke
Q1 - Buying the FPR was prolly a little premature. The idle control valve, or stepper, should open sufficiently to start the car. If you need to feather the throttle; maybe give it a clean. Check the ECU for error codes, clean AFM etc etc. Rape the forums search button for others experiances.
Q2 - Use a penetrator on the screw and let soak... then use some multi grips around the outside of it. Try a "ezi out" if not previous doesn't work. Set the base to 43-45psi fuel pressure.
Q3 - Setting the pressure too high or too low will stop it from starting, but it wont blow up. Setting the pressure too high and running it for a long time could coke your combustion chamber. Setting the pressure too low and running it could blow your motor up.
If you have some basic tools, patience and are able to use the search button on this forum, you should be able to save your self the labour by fitting turbo and dump. I would leave the FPR unless your getting the thing tuned / chipped in the future.
Edited by GeeTR
hi guys this is a link to pics of the turbo i got http://members.dodo.com.au/n0ob
does this have a compressor outlet elbow????
Nope. The middle picture from your link. The silver side on the left is the compressor cover, containing the compressor wheel. The bit pointing down, is the outlet, and a flanged elbow would bolt on there i would assume.
Edited by GeeTR
    • Can't see that being a thing.
    • My fob has never worked, I once attempted to follow the procedure to re-key it, (I have other fobs for the car alarm thing in there). I actually have three of them. Do aftermarket alarms take over the pairing mechanism for central locking? Or do they piggyback off it? I suppose it depends on the system, right? I have four sets of keys/keyfobs. One definitely works, one I think works, one definitely doesn't work, and I have the OEM one that has never worked :p. Is this fixable/workable/whatever? I mean I know it's beyond "just clean it" but how *do* they get synced up?
    • It's actually a really weird comparison... the MX5 is on another level and I kinda question this comparison at all. It'd be closer to compare it to a GTI/Golf/Hatch anything that kicks around. NC MX5 with a turbo has the right to go up with and beat the FD RX7 or 180SX or any other JDM hero car. That's the comparison that would really ruffle feathers.
    • @MBS206 you need more shed in your life... What sort of car is your mates race car?  Hopefully he returns the favour when you're ready to get cracking on yours! None of my mates are into cars so I don't have to worry about that as a distraction thankfully.  I have enough other distractions so I don't need that one too!  Between working 6 days a week (5 1/2 really so 55 hours or so per week), both kids have basketball almost every week night (including Friday night in Melbourne - 2 hours away), my daughter plays netball as well, my sons footy has started now and I coach his under 14's side as well as I'm on the Footy club committee this year, I ride motorbikes every spare Sunday I can find, plus trying to be some sort of a husband.  Life is a busy little exercise at the moment!  I wish there were 8 or 9 days in a week sometimes!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
