I have a turbotech MBC which drops boost off by 3 psi and im not happy with it. I would like to hold the boost at a desired level and im assuming an electronic boost controller will solve this issue. I wanted to know if there were any specific best Electronic boost controllers for GTT R34 or skylines in general.
Im thinking maybe go for Greddy ones, as i found one thats $400 and i thought it was REAL CHEAP for an electronic, but then again im abit worried why its so cheap? maybe it can't hold boost long??
I need some advice on which electronic boost controller that holds boost right thru please. and thanks in advanced...
Some ppl whinge the AVC-R is no good; hard to get stable boost when bleeding a large amount (low wastgate spring tension, high desired boost level) but as with most things, i believe you need to find someone with good experience in the EBC you do choose, (or be willing to ask lots of Q:'s and really research their setup if doing so yourself) ... much the same as a ECU.
Going by your wording, im assuming you don’t feel like spending a lot of time setting up a Gizmo or a Jaycar unit yourself
The dual solenoid unit Blitz SBC IDIII seems to be the flavour atm, the unit without the screen is a lot cheaper. Profec, AVC-R should all suit your need fine providing you have someone that can set them up properly.
I'm using an Apexi-Avcr (blue screen) one had i on the car for ages now.
I've achieved a steady 18-19psi til redline with a VG30 GCG highflow on r34 stock actuator and GT-R Bov along with the Avc-r
going to a dyno day on saturday so i'll post up a graph when i have it.
BUT as others have said mixed results, and i spent some time on the run tuning it.
I bought a gizmo, using on stock turbo would fall from 15psi at 2500rpm to 8psi at redline, I was gett more stable control (14psi to about 12) using the stock double actuator and a bleeder together. Totally disappointing controler! just behaved like a bleeder.
As i mentioned, they can take some time in setting up correctly
thanks for ur help and advice guys...
The boost level im only trying to achieve is 14 psi max, prob alil less down to 0.85 bar, but i don't want it losing any little boost at all. I've always heard the Greddy Profec B or something was really good for it but im pretty cheap at the moment as i got my R33 stolen 2 weeks ago and now trying to do up the R34 with alittle financial struggle.
never ever had an issue.... who set it up? they are pretty fool proof if you read the instructions...... in real time dyno testing we have seen them outdo all but the dsbc from blitz.
If you're looking to get a stock RB25 turbo (assuming you're still using it) holding 12-13psi until redline it won't happen. It's not the boost controller, it's that the turbo can't flow enough air to keep the pressure up. They all drop towards 10-11psi.
I see this response may be too late..
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
