Hello, I am hoping you all could help me with with this
Here is a bit of background on the engine:
I had this engine installed into a 240sx back in 2004, ran good, no big issues. June of 2006 a girl pulls out right infront of me and thats all she wrote for that car. The engine survived, all except for the power steering pump, intercooler and radiator. It has now come time to put the engine in another 240sx.
I was cleaning up the engine today before I put it in the new car and came across this. Seems to be a good amount of oil in the intake. I dont know if this is normal or not. I know a light film is ok but this is a little more than a film, not a giant puddle but a puddle none the less.
I posted this issue on another forum and was given a possibility of three scenarios:
1- Ringlands are bad
2- Turbo seals are allowing oil to bypass and need to be replaced
3- I need an oil catch can
I can crank the engine over just fine using a wrench if that means anything.
I have never ran an oil catch can with this engine (but I will from here on) and was wondering if a long period of use without a catch can could result in this amount of oil?
What is the most reasonable cause for this?
I really would like to know if this is something I need to worry about because at this point it is the only thing stopping me from putting the engine in the car. I am hoping it is not the ringlands or the seals.
oil.jpg Thanks for the help in advance
https://www.sau.com.au/forums/topic/188054-rb20det-help-oil-in-intake/
  • 4 weeks later...
Had the same problem. . . oil in the intake turned out to be blown turbo seals and the oil in the breather pipes was blown rings from excesive crank case pressure blowing the dipstick out and blowing oil out the breather pipes
go 2 a decent performace workshop, i recomend electronic automotive in epping, 03 9408 8122, get a leak down test done, they will test 1 cylinder at a time 4 compresson, then position each cylinder at a time 2 TDC and with both valves closed will attach a air hose to the spark plug hole, fire up the compressor, if u can feel air blowin out the oil filler, ur rings are stuffed.....
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
