Hey guys I’m really desperate to sell my gtr. Just recently got married and also need to put some money towards a house. I’m more than willing to swap and some money my way or just sell, if I were to swap I would prefer non Japanese import. Has been regularly serviced, every 5,000k's sometimes earlier than the service time as well. car has had full major service when it landed in Melbourne, the car had been worked on by a work shop called hokue racing factory in Japan and the bottom end has some aftermarket internals which I’m not sure of, but all the work in Melbourne has been done by Benny kashima from hi torque performance in Dandenong. Car has all receipts of work done to it, only used the best oils, I’m willing to negotiate on price as well. PRICE: $23,500
33 N1 engine
jun cam gears
hks cam shafts
jun valve springs
garret 25/60r turbos
apexi power fc
greddy profec b boost controller with hi and low boost settings.
Turbo timer.
Half cage in the car, black colour.
Rebuilt 33 gtr gear box.
hks triple plate clutch.
short shifter.
apexi air pods
hks intercooler.
trust boost and oil pressure gauge
fujitsibo exhaust, quieter than stock.
sard 660cc injectors.
bosch 040 in tank fuel pump
apexi n1 coil overs
trust brake pads.
slotted rear rotors and cross drilled front rotors
Apexi sway bars and strut brace
aero vented bonnet with bonnet pins
hks kansai front lip.
$2,000 stereo alpine sound system which is still in the box, I have not yet fitted.
rims, not sure which ones.
ATS two way lsd front and rear.
On hi boost 18psi the car produces 350rwkw and still has more in it. I have all the dyno sheets and receipts of work on car as well. My low boost setting is 14 psi for the street and produces 282rwkw. The cams are yet to be dialled in so the car can make whole lot more power as well, I will also throw in a free set of OS GIKEN cam gears. Perfect for circuit racing and drag racing, car is very responsive; boost comes on at 1,800rpm. Car ran a flat 12 sec at 115mph on my old standard set up, with standard turbos, no injectors and no power fc, so the car is ready to run deep into the 11's. I only have one pic of the car so I will post that up. Please don’t hesitate to call, desperate to sell so I won’t refuse any sort of reasonable offer. My number is 0419 326 708, I can be email on [email protected] . thanks.
https://www.sau.com.au/forums/topic/188059-modded-32gtr-for-sale-melbourne/
just managed to attach this one, will try and take some more and will try and post up. come on guys, im desperate to sell this caar, i need the money, feel free to come and see the car when u want.
Edited by Bobbygill
sent you a pm or email a while back (cant remember)
am genuinely interested and have the coin but need a little more info as outlined in email to justify a flight down to melbourne
Richard
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
