Hey guys I’m really desperate to sell my gtr. Just recently got married and also need to put some money towards a house. I’m more than willing to swap and some money my way or just sell, if I were to swap I would prefer non Japanese import. Has been regularly serviced, every 5,000k's sometimes earlier than the service time as well. car has had full major service when it landed in Melbourne, the car had been worked on by a work shop called hokue racing factory in Japan and the bottom end has some aftermarket internals which I’m not sure of, but all the work in Melbourne has been done by Benny kashima from hi torque performance in Dandenong. Car has all receipts of work done to it, only used the best oils, I’m willing to negotiate on price as well. PRICE: $23,500
33 N1 engine
jun cam gears
hks cam shafts
jun valve springs
garret 25/60r turbos
apexi power fc
greddy profec b boost controller with hi and low boost settings.
Turbo timer.
Half cage in the car, black colour.
Rebuilt 33 gtr gear box.
hks triple plate clutch.
short shifter.
apexi air pods
hks intercooler.
trust boost and oil pressure gauge
fujitsibo exhaust, quieter than stock.
sard 660cc injectors.
bosch 040 in tank fuel pump
apexi n1 coil overs
trust brake pads.
slotted rear rotors and cross drilled front rotors
Apexi sway bars and strut brace
aero vented bonnet with bonnet pins
hks kansai front lip.
$2,000 stereo alpine sound system which is still in the box, I have not yet fitted.
rims, not sure which ones.
ATS two way lsd front and rear.
On hi boost 18psi the car produces 350rwkw and still has more in it. I have all the dyno sheets and receipts of work on car as well. My low boost setting is 14 psi for the street and produces 282rwkw. The cams are yet to be dialled in so the car can make whole lot more power as well, I will also throw in a free set of OS GIKEN cam gears. Perfect for circuit racing and drag racing, car is very responsive; boost comes on at 1,800rpm. Car ran a flat 12 sec at 115mph on my old standard set up, with standard turbos, no injectors and no power fc, so the car is ready to run deep into the 11's. I only have one pic of the car so I will post that up. Please don’t hesitate to call, desperate to sell so I won’t refuse any sort of reasonable offer. My number is 0419 326 708, I can be email on [email protected] . thanks.
https://www.sau.com.au/forums/topic/188059-modded-32gtr-for-sale-melbourne/
just managed to attach this one, will try and take some more and will try and post up. come on guys, im desperate to sell this caar, i need the money, feel free to come and see the car when u want.
Edited by Bobbygill
sent you a pm or email a while back (cant remember)
am genuinely interested and have the coin but need a little more info as outlined in email to justify a flight down to melbourne
Richard
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
