Hey Guys,
This car would suit some one who wants a dedicated drift car! Had it on the dyno about a month ago made 264.5 kw at the tread
It rev's to 9000rpm.... very serious car.... the car was built in japan with computer this car could easily make 300kw with the gear that is on there
The car can be complied and registered
need to sell the car will consider trades
call me on 0412 209 069 or pm me
looking for $16,500ono
will strip the car but only if the engine sell first
cheers
NiCk A
ps im located se melbourne
1992 180sx
Tomei 2.2ltr motor :)
Trust TD06-25g Turbo kit (externally gated trust manifold screamer pipe)
Trust Intake plenum
trust manual boost controller
trust revic controller
tuned ecu
17" Volk rims
Twin Plate Clutch
2 way lsd
Bosch 044 external fuel pump
r33 gtr fuel pump(lift to the surge)
External Surge Tank
Roll cage
Bride Brix seat
lots of gauges
Full exhaust system
JIC suspension
the list goes on and on
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
