FOR SALE
Nissan Skyline R33 GTS-T SERIES 2 1996
Hey Guys up for sale is my 1996 series 2 GTS-T R33, genuine reason for sale can't drive it on my p's i learnt the hard way unfortunetly so its time for her to go car specs below__:
Nissan Skyline R33 GTS-T Series 2 Imported july 06 bought 22/07/06 1st Owner in Australia Grade 4 At auction.
97xxx KMS but 100,000KM Service completed @ 95,000KM
White Exterior
Standard 16" Wheels W/ Red Calipers
Standard Series 2 Body Kit
Engine/Drivetrain/Suspension
X-Force 3" Turboback Exhaust to a 4inch tip W/ Hi-Flow Cat
Hybrid Front Mount Intercooler
Monza Air filter W/heatshield/ A/M airbox
Exedy Heavy Duty Clutch installed Monday 1st of October W/receipt for work.
Tien Fully height adjustable Coilvers W/Tien EDFC controller in car for Ride Dampaning.
Custom CAI running to behind front bar.
Interior/Stereo Components
Autometer Phantom Series Boost Gauge(installed by Autobahn)
Greddy Profec B Spec II(used in off mode untill car was ment to get tuned)..(install by Autobahn)
Pioneer 6.5"touch screen DVD player
Soundstream full system including:
Front and Rear 6.5" 120WATT 2 Way Speakers with fronts being Splits
In boot 2x Soundstream Amps 4CH 520WATTS
In boot 2x Soundstream Subs in box 12" 420RMS Each
Car still has Reg till july/08.
Asking $15,000 ONO
Will considering Swapping for a Series 2 S14 200sx or s15 with cash.
Any Further Questions i can be reached on 0414477397 or [email protected], if i dont answer Your call please dont hesitate to leave a MSG and will reply to SMS messages.
Edited by RBWPN.6
  • Replies 41
PRICE DROP $16,750 will consider swap for S14 Series II or just throw we some offers ill check em outs.
Edited by RBWPN.6
  • 1 month later...
Am willing to remove audio stuff to lower price, exhaust is off the car due to takin it through epa but only from cat back is off...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
