hey guys im after some info on what ecu to get for the 31.
ill have the following.
2.25" exhaust
exstractors
k&n pod
custom crow cam
adj cam gear
440cc injectors (gtr)
GTR fuel pump.
im getting a price on a links plus and a mate of mine is getting a autotronic (i think or its the one that sounds like motec)
yea any advice would be good i dont mind what type of ecu as long as it dont cost me the earth.
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/
2.25" exhaust
exstractors
k&n pod
custom crow cam
adj cam gear
GTR fuel pump.
http://home.aanet.com.au/nistune/
Just got one myself, for my 32
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3393886
hey mate thanks for that, thats first company iv'e seen make a reprogramable ecu for the rb30. and for only $400.
can you tell how youve found the ecu so far, and who would be able to tune it, and how easy it is to use compared to other ecus'
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3394494
I have had experience with a motec M48, on my previous r33. Obviously with the Nistune system there is no setting up, i think its a breeze to use, and also great value for money. I already had the eprom socket in my ECU so i only had to solder 4 wires to the board, plug the daughter board into the socket and away it goes. I sent matt the bin file from my ECU, he installed it onto the board before sending it to me and car started straight up with same settings it has had since i bought the chip off Ceffie.
I just installed a z32, took 2 mins to reprogram for the bigger AFM, also have a set of GTR injecters coming and they are just as easy.
Download the user manual from his site, pretty well explains the uses of it.
Ken
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3394585
so all i should have to do is wire up the few wires required as i have a stage 2 chip all ready soldered in (soket type)
look's like i might give it a try then defently should be easy to use from what your saying. so if i had it then was to add a custom cam xf throtal body GTR injectors and gtr fuel pump i could do all the tuneing my self. sounds good esperly for $400
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3394912
www.adaptronic.com.au is what I used to run on my R33.
Only reason I don't now: I'm selling the car, keeping the ECU to use on the next car.
hey mate had a look however the system is not suited to the R31 so thats out.
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3394954
yep
Edited by kjb_r33
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3395888
Why is it not suited to the R31?
They run the same motor as the VL yes?
And I know the Adaptronic is on a VL RB30
according to thier web site they are nnly makeing them for the rb25 eng + some i may be wrong but thats what i read
https://www.sau.com.au/forums/topic/188107-what-ecu-to-use/#findComment-3397684
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
