G'day,
Due to a tight (student) budget, i'm NOT wanting to covert my auto n/a VL commodore to manual when i put in an rb20det I have planned for it...
My Q is: Is the R32 GTS-T auto box heaps worse (in terms of performance) than a manual setup?
I've heard that if it's not turbo, there's a big difference, but autos in turbo cars have advantages such as being able to hold boost through gear changes, etc..
Cheers
https://www.sau.com.au/forums/topic/18811-rb20det-with-auto-gearbox-any-good/
Well my car standard was auto...
I converted to manual due to loss of much needed power throught the drive train... Holding boost through gears changes is a good point as doing this in a manual is just asking to snap a gear box... But because you are holding max boost the air in the plenium is getting hotter and hotter every second until the turbo wind's back a couple of psi... You would be asking for piston melt down if you held it from 1st though 150kph in third...
I have a plem temp meter... When i was auto it would be around 40C at the end of 2nd gear..... Thats with a massive FMIC (Trust core)
Now im manual that same figure it 24C....
Those little breaks between gears helps so much.....
Bozza - that conversion would almost be considered a downgrade. The RB20DET has bugger all torque, and when combined with an auto transmission it will hurt driveability. I would only consider this conversion if you used a manual, but youre really just better off turboing the rb30. The diff in your VL will make the car very lifeless if its a 3.45 or something like i think it is. The R32's have a 4.11 diff.
You have to look at the end result that you get for what you spend, in the end youll get a less driveable car.
Generally - an auto is worse than a manual, and id say especially in the case of an rb20det. How many auto race cars do you see (apart from drag cars which are only run flat out) ?
Drive an rb20det auto (or even a manual) and youll see what I mean.
My RB30E R31 Manual doesnt get beaten too badly by RB20DET cars. Turbo the 3L for best results.
(not talking my car up either, its a shitbox.)
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
