...and The 2007 Bathurst Winner Is...
Who else but Craig Lowndes! Team Vodafone 888.
Spec:
Engine: VehicleTriple Eight Race Engineering Falcon BFEngineSBRE developed 5.0litre V8 Ford with SVO cylinder R302 cast iron block and SVO aluminium heads Category control MoTeC engine management control.
Power: Estimated Power635 + BHP limited to maximum 7,500 RPM
Gearbox: 6-speed Holinger gearbox - Australian made With electronic gear cut
Differential: Ford 9"
Suspension: Front - Triple Eight Race Engineered double wishbone suspension with Sachs adjustable damper and cockpit adjustable front anti roll bar. Rear - Triple Eight 4 link rear suspension with adjustable watts link, coil over Sachs adjustable rear dampers with cockpit adjustable rear anti roll bar
Brakes: Front - Control Alcon 6 piston front calipers with Alcon 375mm ventilated discs. Rear - Alcon 4 piston calipers with Alcon 343mm ventilated discs
Wheels: AutoTek 8 spoke, 17" aluminium racing rim
Tyres: Dunlop control tyre
Fuel Capacity: 120 LitreVehicle
Weight: 1355kg (category minimum without driver)
Top Speed294kph (182mph) 0-100kph: 3.8 seconds
Telemetry: Motec and Freewave 900Mhz spread spectum radio
Data Acquisition: MoTeC ADL2 Display/Acquisition System. 16Mb memory, up to 100 channels of data at up to 2000 samples per second
Seat: Cobra Carbon Race
Steering Wheel: Revolution Sportsline RPM
(Courtersy of Triple eight.com.au)
https://www.sau.com.au/forums/topic/188117-and-the-2007-bathurst-winner-is/
Haha,
Did you watch the top ten shoot out? You'd have known who and which car is on pole position do you? :)
Yeh? I dun get it? :(
and boo! :) Fords 1,2,3 ah well next year :)
Did anyone see hrt's new way of changing disks? how good is it, unclip and slide out, no need to take anything off!
