Ok, if anyone is interested, i will also include the PFC tune to go with these turbos, so you can bolt on, put the numbers in your PFC and away you go.
Ill take the time out and copy the injection map and timing if you want it, and all the other settings in the PFC for this setup, ill put into a table if you like. It doesnt matter what injectors you are running, that can easily be adjusted. I ran 650s.
Even if you wanted to run a little less boost than i did, the map will still be close and if it does need retuning it will be a minimal cost because most of the work is already done...
$1500 for 274kw wtf!
