Fuel surge is some thing most of us never realy concider... untill it is too late.
Surge is a particular problem in drift because the cars spend so much time sliding with lateral G loads pushing the fuel in ur tank to 1 side or the other. The fuel pump pick up is usualy positioned so it will pick up fuel pretty much all the time under normal driving conditions. When the tank is getting low, some times going around a corner you might get a small cough out of the engine. The petrol has run over to the other side of the tank away from the pick up and the pump sucked air for a moment or 2. The pocket of air runs down the line and to the injectors. bop bop bop doesn't make a nice mixture for the engine to run smooth for an instant, It leaned out.
On the track drifting or racing, pushing the car and engine hard, the same thing happens, only under load the lean out is more sevear. A longer starvation occurs, more Oxygen less fuel = more heat = detonation = dead engine. Don't get me wrong here, it's a pantine thing, it wont happen straight away...but...it will happen.
The answer is to run a serge tank which is always full so you dont get surge untill the tank is ptrtty much totaly empty. The normal pump lifts fuel from the main tank into a smaller tank that is usualy tall and skinny that holds about 1.5L. At the base there is a fitting that you connect you hi-pressure pump to the engine which feeds the injectors or carby. the pressure regulator maintains the pressure for the injectors to work properly and retuns the excess fuel to the surge tank. Having the 2 feeds in to the surge tank, (return fro eng and fill from main tank) keeps it full just about all the time. Excess fuel in the small surge tank come out a overflow and falls back into the main tank.
I had 1 made to my own specifications. Cost a few $$$ but it is exactly how I wanted it. Most surge tanks will have normal barb fittings, I needed something more purpouseful.
This 1 is about 3.5-4L with a bosh Intank 600hp motorsport pumpin it. There is a return from the engine and return to the main tank up hi. The fill from the main tank is down low and the feed to the engine comes out of the inturnal pump out the top. The fill from the main tank is drawn from the bottom of the main tank where the fuel should be coolest. it is fed in to the surge tank down low so the hi pressure pump picks up the cool fuel first. The return from the engine goes back in on the same side as the main feed which creates a swirl. This and a horizontal baffel lowin the tank helps keep the fuel stable in the tank. The return is on the opposite side at the top working with the swirl, returning hot fuel to the main tank where it has a chance to rest and cool down. Just some ideas.
pm me if your interested in costing something like this or need something custom made.
https://www.sau.com.au/forums/topic/188138-fuel-surge/
I'm actually looking at changing mine slightly to run twin 044 or 040 pumps... i forget which is the good out of tank ones atm... so the thirsty beast doesn't run close to its limit on the long straights at Queensland Raceway. dual feed to the rail and central regulator return. I'm in the middle of up grading injectors and turbo setup. It will be drinking more juice so i don't want it to run beyond the capabilities of the 1 in tank pump.
over kill?
Edited by Noddy
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3394917
Well depends on how thirsty really?
350rwkw track GTR's here just have a good ole in-tank upgraded one.
And they never have fuelling issues :)
Dont gtr's have a half decent anti surge arrangement standard? Enabling them to bandaid the situation somewhat?
I think old mate has a silvia or gtst so hes not as lucky?
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3394937
well yes ash, but they aren't running 1/4 tank fuel or less are they - keep the tank above that and you will always be fine.
we are doing the 1hr endurance race at oran park in 3 weeks and this is a major concern or us. the long, high g left hander off the bridge leads to fuel surge, and by 55min into the hr we are having trouble every lap - need to drive carefully and remember everytime to make sure we dont lean it out. Would love to run a surge tank but regs do not allow it...we can do a fuel cell so might go that way
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3394946
Well yeah indeed :)
Gotta remember though he is drifting, he isnt out there for enduro's... and nor is are club track-day GTR's out there for more than 20mins :D
So no massive fuel requirements. Twin pumps you gotta be cranking some overtly major horsepower IMO.
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3394982
twin pumps is just a lesson in doing it properly :) Its not about massive fuel requirements, its about quality of supply.
and as far as saying he is just drifting? thats going to throw the fuel around alot more than circuit racing which should be relatively smooth in comparison. well unless you are in giants gtr, hehe.
this is the point where u tell me giant runs one pump in tank with no mods to any thing else and i lose :]
Edited by 2630GTS
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3394986
If I am old mate, it is an r33 GTST logbooked as a 2A Sports Car. It is still powered by and RB25 with good head work, matched custom grind cams and plenty of other goodness. On a mild tune running 1 bar it is happily punching 300 rwkw. It has won its class at every meeting Ive taken it to this year bar 2. I had fuel issues at QR round and ran 2nd to a GTR at the Grafton round of the NSW hill climb champ round. I plan to run the QLD state sports car series next year so it has to perform and be bullett proof reliable.
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3394996
As someone said its not just about volume of supply but quality of supply.
A friend has a serious HP car and like giant runs three pumps. One of the three pumps can supply enough fuel to keep the rail happy but he runs three. The other two pumps are just plumbed in for insurance allowing for a failure of one ...or two of them.
https://www.sau.com.au/forums/topic/188138-fuel-surge/#findComment-3395204
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
