Hey guys,
Have a fibreglass front kit that needs some work.
Any recommendations on where to go in Victoria (I'm in South Melbourne)?
Or if anyone feels confident they could do a decent job then I can forward a picture of the damage to you and you can let me know what you'd want to repair it.
Thanks,
Aaron.
https://www.sau.com.au/forums/topic/188152-fibreglass-repair-where-in-vic/
not in SE burbs, but we do fibreglass repair, prep and paint in house. send pics to [email protected] I'll have one of the guys check it out on monday and send you a quick quote.
shop is Driftline in campbellfield (www.driftline.com.au)
Sounds good. I'll take some pictures today and e-mail you this evening.
Cheers,
Aaron.
Aaron, mate while that bar is off, get those mild steel pipes sanded back and repainted ... that and the repaired bar should clean that front end up a bit
when painting the pipes, ensure you hit them with an etching primer - or a self etching paint so that it wont flake off next time.
I had my intercooler pipes that sit up the front powdercoated black. I thought the powder coating would help fight off stone chips a little better than standard paint. Didn't cost much at all to get them sand blasted and powdercoated, $40-50 total from memory.
Yep powdercoating is alot better, but not everyone has access to this type of process.
Thanks for the advice, definitely needs it :cool:
I've just moved over from NZ, used to go here for intercooler piping:
http://www.procoat.co.nz/ or http://www.hpcoatings.co.nz/
Is there somewhere similar in Melbournethat anyone can recommend?
  • 4 months later...
Abu actually referred me to a fibreglass repair shop near Oakleigh, they quoted $250 to full repair my front bar, probably because it was pretty good it had alot of cracks and chips and on the other side u could tell its been repaired alot with just cheap putty kind stuff. He said he'd pretty much have to re-make the bar in a primer coating.. pm me if u want the details
Edited by cosmokram3r
    • PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger Both are -50*67mm 8 blade billet compressor wheel Cheers
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning) Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
