R33 Interior Wiring Diagram.
Hi guys I need a r33 interior wiring harness diagram can someone help on this one?
If not this is the wirings that I need to find the colors code:
door's sensors=driver and passanger side?
sunroof ( the connector is on the driver's side up in the right corner but I don't know the wiring colors=?
interior lights=?
seat belts (driver and passangers f&r)=?
taillights brake signal=?
hazards=?
reverse lights=?
Just tell me the wiring's color for one of the things mentioned will be really good for me to try to finish my project!
Thanks for any help!
yes I have reading almoust everything and looked in a lot of fsm and I couldn't find it!
It's not for radio it is to make everything to work, I got a r33 front clip and I've installed and customed a lot of thing so I need to know these things to finish my project!
yeh i need an interia loom wiring diagram too been looking for like 3-4 weeks and havent found one, i'd be happy to buy a manual but i've got a couple that i downloaded and they dont have the interia loom on them only accessery ones and the ebay ones seem the same so i dont wana buy one that doesnt have it n i dont think haynes or gregory make them for skylines grrr
I'm about to finish the interior lights and some more things like sunroof and more... so as soon as I finish it I won't mind to post pics and specs here!
But if some one can take a copy from the fsm book and post here I'll be really happy.
Edited by dk_fabiosantos
Not yet!I still need it but most interior I found the hard way like: room lights are the wirings on the driver's side on the right top with a white connector with orange/blue (2 wirings) and one going to the back the same color orange/blue, I'll post the wiring pinouts soon with some pics.Right now I'm trying to find the power for the locks(I can't lock or unlock the dorrs and move the windows up and down too.)
What you need to know? I probablly know it.
And if you find it let me know please cause I have to find a lot of things still!
Thanks!
This is what I found:
fuel pump from cluster:
level- light= gray/red
low fuel light= light green silver pin
reverse light= red silver pin (coming from trans. sensor)
turn signals=
right side=green/yellow (hazzard is connect to this one too)
left side= green black
air regulator= blue silver pin (from air regulator located at the intake manifold and it is going to pin 5 on fuel pump relay.)
brake lights= pink/blue & yellow silver pin (coming from brake pedal sensor)
door's sensors= red silver pin (coming from black box "smart entrance".
There is the abs wiring harness on left side (pass. side) that I've disconnect all of them (one is ignition earth that I have found exactly for what is that.anyone know it?)
I don't remember the hicas right now but I'll post the wiring pin soon.
well i bought a burnt out shell cause i wrote off my old car and the shell has abs and airbags where-as mine didnt so when i swapped over the wiring i dont have any looms to connect the abs or airbags so im trying to do it custom i've done most of the airbags rather easily but the abs was almost completely burnt out so im not sure what wires go to where would be a lot easier to determin if i had a proper wiring diagram
I did the opposit of it, I've disconnected the abs and my car never came with airbag so I can take some pics of the abs wirings and tell you more or less where they go.
I've disconnected my abs from the fuse box (2 red wirings: one is all red and the other red/blue connected to a fuse), they go from the engine bay fuse box to a gray connector on the passanger side (near the pw sterring reserviol), then from the connector the abs actuator and I can't remember everything right so I'll try to post about it tomorrow asp, anyway at least you'll be able to connect everything (you'll be able untill the middle of the car,cause I had my front clip cutted right there in the middle!), I hope it is going to help you in some way!
well mines the oppisite lol, i've got the rear clip but not the front section of the wiring it was burnt up into the pasenger footwell everything from there back was ok, it would be greatly apreciated if you could post some pictures or if you in melb mabye i could come down have a look at it in person.
Ya man for sure!I'll post the pics of it assemble but not in place cause it's really a pain in the a$$ to do man!
So I'll do that asp!
yeh thats cool dont have to be in place i can work that out any help is better than none, thanks for that, dont rush just when you get a chance i've still got lots of things to do on the car to occupy me before i tackle abs i've almost got the car startable but no where neer drivable.
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
