Wheel Bearings
Put v2 of the tune on it today, and ran the performance test with Launch Control on and Traction Control off. Went 5.67 0-100 and 14.05 for 400m which is a fair bit better I also put together a boost/turbo speed/AFR graph. Not sure what the blips in the curve are and the AFRs seem pretty lean on boost compared to what you would do with an RB, I'll talk to the tuner about it This is the temps and oil pressure, at 35o ambient temp for the run. Good to see charge air temp (post turbo) going down not up as speed increases.
By DraftySquash · Posted
Success! battery voltage needle calibration is a bit off but oh well -
Cheers Lith! You're right, it's entirely possible that there's other reasons for the low compression. It's off to the shop soon, skipping borescoping etc and just getting it out and apart, we'll see what it looks like then.
Wanted to clean the film behind the triple gauge so the lights show through better. Progress so far….
