As some of you may know i have just had my engine rebuilt with arias forged pistons and just got it back on the road after every problem that can happen to someone. The car started out as a N/A and i converted it to turbo (BAD IDEA. . . . ) and now over 25 grand later i regret it more than anything in the world.
The problems i had were clutch and the turbo blowing at the same time while on the dyno, which put oil all through the new exhaust, the next day the fuel pump went, then the injectors couldnt keep up, then a few days later the motor blew. By this time it was too late to do anything as i was moving to karratha.
When i got here i started stripping the motor and sent the block away to be rebuilt, finally things were going my way. . . so i thought. I got the motor back in the car and started to wear it in.
I was curising along at bout 110-120 to burn out all of the oil in the exhaust which looked like it was working. . . then bout 20 mins later thick white smoke started coming out of the exhaust like the rings had gone again and also sprayed oil everywhere (in the engine bay) again which was another problem i was having. . . the dipstick kept blowing out.
So my question is this. . . What the hell do i do because im ready to drive this car over a cliff. . . .I have had more headaches and problems with this car than anything in my life.
Do i fix it again and just wait for it to happen again, or do i just strip the car and sell it in bits and then buy another skyline (R34 GT-T) or just sell the car as it is. . . . Any help would be awesome guys as i really am lost on this one, ill put a list of mods so you can see if its worth fixing or gettint rid of
Mods to it at the moment are
Haltech E-11 ecu
Xforce 3in turbo back exhust
High flowed, steel wheels and new seals in the turbo
Walbro 550 hp in tank pump
300 x 600 fmic
custom piping
Turbosmart supersonic bov and plumb back kit
Arias forged pistons, rings and pins
Autometer guages (tacho, oil pressure and air/fuel all cobalt series)
Custom front bar
This is a video of when it happened Edited by Daniel R32
https://www.sau.com.au/forums/topic/188181-32-is-dead-again/
Gee mate that’s not a good story at all.
Personally I would consider stripping and selling, and buying a 34GTT as you mentioned. It is an expensive exercise trying to make a NA car turbo (as you seem to already know), it goes so much further than just the engine and therefore is $$$ and there can be little re-assurance in determining what the outcomes may be. Usually if you have a trust worthy and highly skilled mechanic and tuner on hand this type of project can be successful. Plus the fact that you probably dont see the 32 in the most positive light anymore...
Anyway good luck!
Gee mate that's not a good story at all.
Anyway good luck!
Yeah i got a really good mechanic. . my dad he ued to work on jags, porshes, rolls royce, ferraris and other stuff like that and also all the mining equipment. Also had it tuned at intune performance by aaron and hes helped me out alot.
I do still see the 32 as a good car but now im just over my car and want to start fresh
Cheers
here:
http://www.skylinesaustralia.com/forums/t1...html&hl=pcv
this is all i could find
pcv stands for positive crankcase ventilation
its a little one way valve that relieves built up pressure in the crankcase
if thats buggered then pressure can build up and boom - out comes your dipstick
should be screwed into your rocker cover somewhere and the hose from it goes into the plenum
Edited by 342Four
so you in effect had no pcv at all??
i reckon it would be worth pulling it out, cleaning it with carby cleaner so it rattles properly, check all hoses that come from the engine and go to the plenum for leaks
My dad seems to think the rear seal on the turbo has gone again, even though it has been rebuilt. There is too much smoke coming out to be a blocked hose or something like that. Ill put up a vid when i work out how to
guys i dont think he wants to spend more money since he just spent a pile rebuilding the engine... now your sugesting that he go and buy another engine?? i wouldnt if i was in this situation..
take it to a mech and get him to figure out the problem
