The original plan was to drive this around with just bolting on a turbo for as little as i could spend which nearly happened for under 2k, till i couldnt find a turbo ecu (no one wanted to seperate it from the half cut)
The idea was to drive that around and get used to a turbo car while i built a 26/30 combo with the best parts in it, which was going to take a while but my motor gave way before i could even start (oh i got the 30 bottom end that was it) so i fixed this motor and thought cool i can start building my 'big' motor now, then a few days later (yesterday) it gave way again, and i dont wanna get another motor or really fix this one again and then put the 'big' motor in
Its a hard choice on what to do but i might have a better idea once the guys that built the bottom end have a look at it, which will hopefully be this week. . . .
probably would have been a better idea to just stick in the big motor and drive around on low boost... an rb26, stock isnt that powerful
Yeah it is but i wanted to do the 26/30 but my motor gave way before i could start building it. I was gonna build the 26/30 over bout a 1 to 1 1/2 years but since my motor blew i had to fix it as i had nothing else to put in
If that makes sense?
Ok found what it might be.
The 2 breather hoses on the rocker covers were conected to the intake pipe just before the throttle body which when it built up boost was putting it straight into the rocker covers.
We had the guy that built the bottom end come round and have a look and as soon as he said that we could see the problem.
I feel like an idiot now for missing something so simple but it was good to have a 'fresh' set of eyes to check it out, i was looking too hard for something more complicated.
It still smokes but nowhere near as bad as before, ill give it a few runs this week to see if it improves
Cheers for the help and sugestions guys
good to hear , you have it sorted.
when running it in, one good way is to not run any boost at all for first 500 kays or so( many different theories but thats how we do it)
cheers russ
Its been very hard not letting boost come on. . . it starts coming on at about 2500rpm
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
