The original plan was to drive this around with just bolting on a turbo for as little as i could spend which nearly happened for under 2k, till i couldnt find a turbo ecu (no one wanted to seperate it from the half cut)
The idea was to drive that around and get used to a turbo car while i built a 26/30 combo with the best parts in it, which was going to take a while but my motor gave way before i could even start (oh i got the 30 bottom end that was it) so i fixed this motor and thought cool i can start building my 'big' motor now, then a few days later (yesterday) it gave way again, and i dont wanna get another motor or really fix this one again and then put the 'big' motor in
Its a hard choice on what to do but i might have a better idea once the guys that built the bottom end have a look at it, which will hopefully be this week. . . .
probably would have been a better idea to just stick in the big motor and drive around on low boost... an rb26, stock isnt that powerful
Yeah it is but i wanted to do the 26/30 but my motor gave way before i could start building it. I was gonna build the 26/30 over bout a 1 to 1 1/2 years but since my motor blew i had to fix it as i had nothing else to put in
If that makes sense?
Ok found what it might be.
The 2 breather hoses on the rocker covers were conected to the intake pipe just before the throttle body which when it built up boost was putting it straight into the rocker covers.
We had the guy that built the bottom end come round and have a look and as soon as he said that we could see the problem.
I feel like an idiot now for missing something so simple but it was good to have a 'fresh' set of eyes to check it out, i was looking too hard for something more complicated.
It still smokes but nowhere near as bad as before, ill give it a few runs this week to see if it improves
Cheers for the help and sugestions guys
good to hear , you have it sorted.
when running it in, one good way is to not run any boost at all for first 500 kays or so( many different theories but thats how we do it)
cheers russ
Its been very hard not letting boost come on. . . it starts coming on at about 2500rpm
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
