OK guys & girls im looking/thinking about selling my pride & joy to upgrade to GTR but will only sell at the price i want! No offers!
STRICTLY EOI AT THE MOMENT!
1996 Series 2 GTST with dual air bags, Rare Active Lsd Model, now with mechanical diff
$18,500 rego expires on Nov 2 07
127,000kms serviced regularly 3,000-5,000kms
Plates WPN-033
EXTERIOR
R32 GTR Rims with new rubber on the Front, will supply standard rims painted black
Stealth/Drift wing
Nismo 400r Style Side skirts
Fibre glass lip on standard bar - in bad condition.
Reverse Sensor... comes in handy
Clear Nismo Indicators
INTERIOR
TRUST gear knob
Knock link
Blitz Dual - SBC boost controler
Clarion CD player
Central locking
3 point immobiliser
Window tinting
Greddy Twin A-Pillar with 1 x Air fuel ratio & 1 x Boost gauge
ENGINE
Hybrid front mount intercooler
Greddy catch can with earls firrings
Master cylinder brake brace
Sard 500hp fuel pump
Sard 650cc fuel inj. Std injectors will be provided
Sard fuel pressure reg.
Splitfire coils
Highflowed turbo by Precision Turbochargers
Brand new Braided Oil lines to the Turbo
LINK ecu
3 inch exhaust from turbo back
Blitz NUR Spec muffler
Exedy heavy duty single plate clutch
K&N airpod with cold air induction through the front bar
HANDLING
Tein HR height adjustable coilovers - Also will supply original suspension
GTR rear sway bar
Tomei electronic Hicas lock kit
Brand new Brake Pads Bendix Ultimate on the front
Bendix pads on rear
Mechanical diff. pretty sure its a 2-way
Adjustable rear camber arms
Serviced just this week 15/03/08
I had the car dyno tuned recently at Croydon CRD, Also fitted a new CAS- Crank Angle Sensor & new 5'' Stainlees Cat Converter.. 3/8/07
Power is 232rwkw on 17-18psi
Most mods were perfomed by Advan Performance & Had engine Drive belts replaced earlier at SAS .
All dyno sheets & receipts will be provided
PM If you are interested in this car.
https://www.sau.com.au/forums/topic/188182-r33-gtst-s2-silver-with-mods/
I see this car everyday. It is tough yet subtle, goes bloody hard and sounds horny as.
I'll put it this way, if you are in the market for an R33 Series II you need to have a look at this car. I seriously doubt you'll be able to resist paying the asking price once you experience this package.
:D
might you be interested in swaping for a GTR?
http://www.skylinesaustralia.com/forums/t187303.html
PM SENT.
Hey thanks Drew, i will miss it if it goes...
Hey phill, thanks for the kind words, & yeh i know lea has a nice car to swap but hmmmmmmmmm its not nice for me :dry:
Hey bill..
Can really give the thumbs up to this car..True and honest example of a series 2..the hard works been done and the mods are there to back up all the work..(DONT SELL IT BILLY)you might not miss it but i will..haha
Owner will defanatly not look back.. geniune car guys..
  • 1 month later...
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
  • 4 years later...
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
