Hey guys, I have a fairly stock r33 series 1.5 and i think my turbo is dying, makes a noise when cold at about 1500rpm. anyways i want to upgrade to a ball bearing turbo. am thinking garrett, i want one about the same size as stock only so i don't lose the low end response. I don't want to have to wait later in the rev range to pick up. anyone got particular models in mind? I don't want to have to do many mods either. any help with this would be great. also if anyone can tell me exactly what the flanges are on a standard setup would be great.
Thanks guys
Lloyd
https://www.sau.com.au/forums/topic/188241-rb25det-upgrade/
depending on how much power your wanting, what your going to be doing with it, and how far your wanting to go with it?
a turbo that will bolt straight up to your std manifold and dump is going to be a ball bearing hi-flow r33 turbo, which GCG can do for the cost around 1750.. which retains same spool time if not quicker and capable of 270rwkw.
considering what boost you will be running, i would consider lifting some of those restrictions, such as dump and exhaust system if you haven't already done that.
after that would be a decent front mount intercooler, and an electronic boost controller to help keep boost levels under control.
That will most probably entertain you for a while, then its onto a aftermarket ecu, (upgrade AFM, but will depend on what ECU you get as some have inbuilt MAP sensors, which you want need a AFM anymore). Then fuel pump, injectors, BOV. You will most probably be capable of the turbos limit at that stage, and close to your engines safe limit aswell, depending on your tuner.
those mods listed will be an easy 5 grand, so i hope your mechanically minded, or willing to have a crack at doing some of teh mods yourself as it will save alot of money for someone else doing it for you. Also will give you an understanding of everything, and if you encounter problems you will be able to determine what it will be, or more of an indea anyway.
Anyway alot of reading for you to do, most enquiries will be available through the search button, as they would have been answered to death already.
To give you an idea, i remember starting where you are, i wasn't planning on going to far with it as i though it was fast to start with (i had a gemini for a first car).
i got hooked i now have 240rwkw, am currently rebuilding an engine and have already spent 14 grand plus on my car.
https://www.sau.com.au/forums/topic/188241-rb25det-upgrade/#findComment-3395279
Seeing as your car is fairly stock you will be up for some big dollars if you go for a bigger or even a highflow turbo.As you will need to upgrade other things for the new turbo and engine to work properly.
So if you dont want to upgrade your cooler,dump pipe,boost controller,ECU and injectors i would advise you either source a second hand turbo or rebuild your stock one.
https://www.sau.com.au/forums/topic/188241-rb25det-upgrade/#findComment-3395484
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
