Hey guys, i went to check my brake fluid level today as i just replaced both front/rear pads for my r33 gtst, and found that the fluid was right at the top of the reservoir, and i think i saw traces ov it being spilt!.What could cause this to happen?and how to i get it fixed?
been searching the forums, and the diy thread on changing brake pads never mentioned bleeding the brakes at the same time, which i think i was meant to do, could i have cause serious damage to my cylinder now?as i didnt take off the nipple, or the master cylinder cap when pulling back the pistons on the caliper.
Edited by nsta
Did you take off the cap on the reservoir before you took the pads out?
When you push back the pistons on the calipers it forces the fluid back up the lines hense over filling in the reservoir.
I undo the bleeder when i'm pushing the pistons back, for the reason you just encountered, and because i dont like the idea of pushing old fluid back into the system. I'd rather add new fluid to the master when i'm pumping it back up. It should be ok tho, just bleed it now, pump it up with the pedal and drive carefully until the pads bed in.
Yeah just wash the spilled fluid off the engine bay (but dont get any on the master)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
