  • Replies 58
Posted Images
If its factory R12 have it refilled with R12A as its more efficient, easier on your a/c pump, hoses etc and environ friendly to the atmo than R134A.
Don't confuse R12A with R12.
Its also a LOT cooler and you don't feel the power sap when you turn the a/c on UNLIKE R134A. :(
You'll need to find some one licensed to deal with it; a lot of the people are not so if they try to bag it in order to sell you crappy R134A then go somewhere else.
The bloke I use is on O'Sullivans beach road Lonsdale. Forget the name of the place; he's on the northern side of the road around half way down.
https://www.sau.com.au/forums/topic/188258-ac-re-gas/#findComment-3395517
R12A is a tad more expensive even though its basically BBQ gas. :P
Mine cost $138 for a vac and refill with dye. From quotes I received around 120-140 was the going price.
I was told to avoid the R134a with the R32/R33's air con compressor as its not designed and doesn't cope well with the high head pressure of the R134A gas. I remember when I had R134a in mine; it noticeably sapped power and made the aircon compressor audible inside the car.
The R134a is apparently 20% less efficient so it places a greater head demand on the condenser which in turn pushes hotter air through to your radiator and places a greater parasitic load on the motor via the compressor.
Only 'some' places deal with R12A is because in large quantities its highly flammable and apparently requires a license to work/purchase it.
https://www.sau.com.au/forums/topic/188258-ac-re-gas/#findComment-3396110
nissans doesnt do R12A the guy their knew where i could go but he said he cant tell me? ahhaha and another guy said good luck in finding a place that do R12A.. ive been to a few places no1 seem to have R12A =/ damit!
https://www.sau.com.au/forums/topic/188258-ac-re-gas/#findComment-3397960
When I first had mine regassed it wasn't that cold... Checked out the aircon evaporator and it was covered in dusty junk that was impossible to remove. Replaced the evap core with a clean one and it was so so cold it would make your bones hurt in your hand when placing it in front of the vent.
It would also make your cheeks very cold to the point where I used to manually turn down the a/c on fan speed 2. :)
Putting the multimeters temp probe in front of the vet I was seeing 0-2degree's. :( Super Icy.
https://www.sau.com.au/forums/topic/188258-ac-re-gas/#findComment-3398352
ok heres the facts from a fridgy
R134a A/C systems run a synthetic based oil in the compressor, its in all new cars from '94' onwards
R12 is mineral, running either or in the wrong system WILL do damage to your compressor, which in turn will put more load on the compressor and give you that zap in power
my mate was very disgusted in the R12A is a tad more expensive even though its basically BBQ gas. statement and had this to say about it
R12a if CLAIMED to be LPG, is a timebomb waiting to happen as soon as you get a leak and a spark or point of high heat say a turbo
he said there is about 4-5 replacements for R12 and that he has a chart with all the different options
the one that kept comming to mind was ICEON 39 aka R413a
now further to my research on the R12a because my mate wasnt sure what the 'a' ment he said sound like some kind of blend but had no idea so i told him its somthing i can google and i come up with this
CLICK last quote
https://www.sau.com.au/forums/topic/188258-ac-re-gas/#findComment-3401212
lol the bbq gas statement was not to be taken seriously.. But as you can see (propane/butane) it is partially a bbq gas. :yucky:
The 'if claimed to be bbq gas/disgusted' statement; it doesn't sound like he knows what R12a is??
I spoke to the gas bloke who's a neighbour and deals with R12a before having mine gassed.
He said its definitely not a time bomb in a cars a/c system like many say. The amount of gas within an a/c system he said its not dangerous and is no more dangerous than R134a. It requires a naked flame to ignite as does R134a.
The large amounts used at a workshop yes it is. He said within the industry he has never heard of R12a causing an explosion within a vehicles a/c system.
Also after a little googling it appears R134a is flammable at 720degree's and R12a at 890degree's.
So a lot of people who don't really know make a lot of generalisations. I remember something being mentioned of why R134a has become the gas of new car a/c systems; something to do with the people who make it; politics and being in bed with car manufacturers.
The bloke across the road said not to worry and go with it as its a good thing. :nyaanyaa:
https://www.sau.com.au/forums/topic/188258-ac-re-gas/#findComment-3401282
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
