just about to purchase my 1st set of Rays and was calculating sizes and offsets with a buddy from Musecret.
we calculated for the rears there would be a total for 127mm of dish and the fronts 87mm. with offsets of +15 and + 8 respectively
he also mentioned they were type B (something to do with the amount of dish and break clearance)
he also mentioned that having smaller offsets puts more strain on the car and results in lower handling, performance ect ect
was quite surprised but some how it makes sense.
was wondering if anyone could shed some light on the topic.
oh also do u guys rkn the dish is to much?
https://www.sau.com.au/forums/topic/188265-offsett-affect-performance/
Type A, B, etc mainly refers to the face of the wheel and sometimes spoke curvature/dish, where certain types are designed to clear big brakes, while others arent.
A lower offset putting more strain on the car doesnt make any sense. Perhaps more strain on the wheel itself if the offset is something mad like -20.
The way I see it, the only way a lower offset can affect performance is that the wheels sit further outwards, giving the car a wider base, making it more stable, sorta.
On a side note, for those offsets you're gonna need guard work or some massive camber.
Edited by Yawn
not true. basically the further out from the hub the wheel centreline is the more strain is put on the hubs, suspension and most of all the wheel bearings.
I agree with BB, lower offset, means widening the track width = changing the center of gravity of your car and hence putting additional strain on suspension parts eg bushes etc....
That said, there is an optimal range of offsets which will be bugger all impact on the above...+8 might be pushing it or anything with a -ve offset...
True, makes sense :)
Is it a noticeable strain though? Like handling affected, suspension components failing more frequently, etc.? Or more of a theoretical strain?
Edited by Yawn
thats what i was worried about......with those specs do u think i would be risking serious damage or anything? i have plans of 300+rwkw.....so im a little worried about low offsets doing some dmg
How wide are these wheels with the +15 and +8 offsets?
19x11 on the rears and 19x9 on the fronts
would like to know this aswell. im getting a suspension kit from sydneykid to better the handling.....i hope having these wheels wont make it worse off
Edited by R34NRG
most notable stress would be on wheel bearings IMO. bigger offset = wider track. wider track means the car *should* be more stable through corners, cant really see any drawbacks in relation to handling, unless your alignment is thrown out by something
well basically the further out you go the bigger the problem. if you started with your stock 17X7 +38s or whatever they are. and you go to 19X11 +20 off the top of my head that's about 65mm further out. plus they are much heavier (even if the rims are lightweight there is no such thing as a light weight 19inch tyre) so yeah it will be putting more strain on suspension and bearings. but a wheel in that size is all about looks anyway as they would be useless from a performance point of view so I wouldn't worry about it too much. probably the only consequence you will find is that you flog out wheel bearings much faster than normal.
you'll crash it anyway so what's the point?
also you should note that changing your track can make you car illegal. in VIC, you can only widen the rear track on an independant rear suspension car by 25mm (front is also 25mm), so that is 12.5mm per wheel. so that means you can only change the offset of the wheel by 12.5mm.
also having a wider rear track than front track can make the car a bit more unstable going into corners under brakes, and slightly easier to roll. having a wider rear track makes the dynamics a bit more like a trike.
That's f**kin gay. I always thought it was 25mm on EACH side, but it's all together. Everything's f**kin illegal.
Would those wheels rub against your coilovers? They're pretty wide wheels on such a high-ish offset.
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
