Hey All,
It has come time to sell this car, I am selling it on behalf of a friend who has since moved to America. This car is VERY quick and is a real head turner. Below is a list of all the modifications that have been done to the car, if there are any questions please feel free to pm me or give me a call on the mobile number below.
PRICE: $17,900ono
Location: Morisset, NSW (about 50mins north of Hornsby (Sydney))
CONTACT DETAILS: PM or Mobile: 0403 363 143
1995 dec built r33 gtst, 98000kms,
ECU/Engine/Exhaust
350rwkws
APEXi power FC with H/C
Garrett T04Z 800HP twin ball bearing turbo.
Turbo smart 45mm waste gate with dump to atmosphere.
6 boost high flow exhaust manafold
Trust type-R BOV
Tomei 264 in/ex camshafts
Tomei 280L/H Fuel pump
NISMO 550cc injectors (This is what he was told when he purchased the car, but when the car was dyno'd the tunner said they were more likely 660cc)
NISMO Fuel regulator
NISMO Oil cap
Fujitsubo 3.1/2in exhaust with high flow cat
3 1/2in custom dump
Greddy Exhaust Adjustable Cam Gear.
Greddy Engine Oil Cooler
Greddy Oil Catch Can
Greddy Intake Plenum
Greddy Profec B boost controller
Port and polished RB25DET head
Q45 Throttle Boddy 90mm
Q45 AFM 90mm
Suction and cooling
APEXI power Intake
TRUST V-SPL Intercooler kit
Drivetrain
C's Quickshift kit
OS Giken Twin Plate Cllutch with lighten Flywheel
NISMO Oversixe slave clutch cylinder
Handling
Tomi Brake Master Cylinder Brace
FET Strut Tower Brace(f)
CUSCO Strut Tower Braces ®
DBA Drill and Slotted Roters (F&R)
Bilstein Strut and Whinelint Spring
Section HICAPS Lock Bar
Whiteline Handling Pack
Whiteline Urethene suspension bushes (F&R)
Whiteline anti-roll bars (F&R)
Interior
APEXI EL Mechanical Boost Gauge
APEXI RSV with DIY shift light
MOMO Steering Wheel
MOMO Gear Knob
Pioneer MP3 Head Unit with Pioneer Speakers/Spliters (F&R)
Exterior
R33 GT-R Front Bar with indicators
R33 GT-R style Rear Wing
R33 GT-R Style side skirt
3 Point immobiliser Alarm
The car will be sold with the STD R33 rims, not the 19's in the pics.
The photos can be found here: http://www.pbase.com/thedarkraver/r33_skyline
or as an attatchment to this post.
Will try and find the dyno sheet to scan in this week.
Whoever buys this car will not be disapointed!!!
Marc,
Edited by ThEdArKrAvEr
https://www.sau.com.au/forums/topic/188309-1995-r33-350rwkw-monster/
Another Price Drop!!
Come on ppl this car needs to go!
It is a very neat example of a R33 and is mechanicly A1, not a cent needs to be spent on this car!
Forged Internals???????????
264 tomei cams, which by logic are procams which need to used with solid lifters... Have you changed the lifters or are they still hydraulic???
Edited by redevil
No the bottom end has not been touched still std internals. When it was tuned they only took it to 20psi as this is what they considered the limit for stock internals, with forged internals the supporting setup with the T04Z should be good for 400kws.. Before he left for america he was sourcing a rb30 bottom end and was going to take this route but things changed and now the car has to go.
still std hydralic lifiters as the 264's lift does not exced what is possible with the std lifters. The next cams up 270's had a higher lift and thus needed solid lifters.
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
