Hey,
Ive noticed recently that when i reach 100km/h i get a huge vibration feeling throughout the car.
Cant even see through the rear view mirror as its vibrating.
Vibration can be felt through seat, gearstick etc basically the whole car.
This started to happen after a new clutch install...
Is there any chance this could be caused from the installation?
Thanks
https://www.sau.com.au/forums/topic/188319-vibration-at-100kmh/
  • Replies 51
was the flywheel machined properly? wat sort of clutch was installed? was the tailshaft done up properly? is the crossmember rubber mount done up properly? the 2 little bolts in the middle of the crossmember get forgotten about alot
flywheel was machined by workshop
exedy heavy duty clutch with 1050kg pressure plate
Not sure about all the other questions as workshop/mechanic did the swap.
Will be going tomorrow to have a talk.
Just wanted some info from SAU before i head over there :P
Took it to a wheel/tyre specialist, they took car for a test drive and said it wasnt wheel balance/alignment related.
Taking car back to mechanic on Friday to see if he can fix the problem, mentioned to him that it could be tailshaft and he said it could be a possibility.
thanks turboedsloth
Yeh, i suddenly had a haggard vibration through the tailshaft of my old gts-t once at a pretty high speed, arrived at home and had a look under the car, 1 of the bolts from the bracket that bolts the tailshaft to the undercarriage had fallen out and it was hanging on a 20 degree angle, luckily no damage, evil thing
Just got back from mechanic which double checked the tailshaft.
Everything is tight and put back the correct way (tailshaft was marked upon removal etc)
Ill book in for a 4wheel balance regardless of what the test driver said, that way i will be 1000000% sure it isnt a balance problem hehe
  • 1 month later...
I am having the same problem with my GTR. Judging by the fact that you have a GTS-T, helps me rule out anything to do with the 4WD system.
I can tell you it isn't a wheel balance because I just had new tyres put on a week ago accompanied by a full electronic wheel balance. Everything showed 100%.
I have been told it could be the diff and so far, I am believing it. If you find out before I do what the problem is, could you please let us know?
I'm in Melbourne too and wouldn't mind meeting up to know for sure if you're problem is the exact same as mine. Sounds like it though.
Fulvio.
PM sent, mechanic also mentioned that if a wheel balance doesnt fix the issue, then it could be the diff.
Getting camber/castor/steering rack/pineapple bushes changed as we speak along with remove/replace of a leaking power steering rack.
I will let you know if i still have a vibration problem afterwards
hrmm
well all my suspension bushes have been replaced and a 4wheel balance & wheel alignment were done yesterday.
Vibration is still there at 100km/h
Went back to the suspension place to double check everything, and he mentioned that if the vibration is felt through the back seat, floor etc then it is a driveline vibration.
Also mentioned that it is the tailshaft as in the r32 its in 2 parts or something and happened after clutch install.
hey guys! i just had a similar prob, i had a gearbox replaced and the car had vibration
at over 80kph, it ended being the centre bearing was shit and the tailshaft needed to be 15mm longer. but the damage also went to the yoke seal on the gearbox.
best thing to do is take it to a driveline specialist. not including the price of the box,
that monkey mechanic who didn't check his work has cost me $1200.
could have bought a rb25det box after all,, :D
excuse my stupidity but where is the centre bearing you speak of?
i have the same exact problem aswell, approx 105km/h and it shakes, only gets worse and you go faster too
have a feeling its the diff or gearbox as it makes a grinding noise between 2-2.5k on each gear aswell AND also can hear a bearing spinning noise (input shaft bearing?) when the clutch is not pressed and its sitting in neutral
tek 01, the centre bearing sits roughly half was between the gear box and the diff... best way to check if it's buggered or not is to through yourself under the car...may need to be jacked up at the rear and push and pull on you tail shaft, if it moves around and clunks it's stuffed... if it stays relativly 'center' it's not you centre bearing... we have a distributer in makcay called hardy n spice.... thats where i got mine from...they seem to know there stuff
sounds alot like your thrust bearing...is it absolutly every gear that it grinds at 2-2.5 k?........ how many K's on the car?
    • No. GKTech arms have spherical bearings in them. No bushes. You will not need bushes for those arms. The sphericals are a bit of a maintenance nightmare. I have replaced all of mine several times in the 5 or so years I've had them, and I have the arms out regularly to clean and lube the balls. Worth the pain on an R32, because the standard arm design is trash. If you need the camber adjustment, there are other options (than the GKTech ones), although I would still lean towards and prefer the GKTech ones, even with the maintenance load of the sphericals. The caster adjustment is also highly valuable, allowing for setting the car up to drive straight. There are a million options for these, including the GKTech ones. I've had Tein rods on mine for 20 years and the balls are much less trouble in that location. Never given me a moment's pain. All positives, no negatives. I consider them compulsory.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
