  • Replies 51
by 75k i mean it was bought with 53k on the clock which i doubt is true (as in the importers etc wound it back like they do with most imports)
yes gearbox oil has been changed with i think it was vmx80 and nulon additive
  • 3 weeks later...
good luck man these things drive u crazy
still have to fix a couple more things like my f**king brakes oh how i hate them and also the grinding noise i get at about 2k on each gear (hopefully new clutch/machine flywheel will fix that)
  • 3 weeks later...
WOHOO, got 4 new tyres wheel balance and alignment and its gone
thank god.
even tho i bought the car with 4 new wheels they must not have balanced them (even tho there were weights on there?)
they must have not been balanced properly, where they stick on weights or hit ons?
if your steering wheel vibrates at bout 100kms, then your front wheels need balancing.
if its at slower speed its usuall a seperated tyre or buckled rim.
from your friendly neighbourhood tyre man.
  • 1 month later...
an update on my problem, my mechanic got the tailshaft balanced to see if that will resolve the problem.
They said it was slightly unbalanced and re-balanced it.
The vibration has mostly gone away, not as bad as before, but its still present at 100km/h+
My mechanic suspects its the tyres, will try swapping with another set of wheels to see if this fixes the problem.
However, if the vibration was slightly fixed with the tailshaft balance, doesnt that mean there is more of a chance of vibration in the drivetrain rather than the tyres causing the problem?
cheers
  • 1 month later...
Well decided to swap my rims with another set of r33 stock rims with new tyres.
Got all 4 wheels balanced too.
Vibration still there at 100km/h+
Next step is to have the clutch removed and rebalanced...hopefully this will finally solve the vibration ~_~
God, I hate hard to diagnose problems like this. I feel for you guys! I had terrible shaking for about 6 months, and threw a lot of money at changing out parts to try and solve it (due to inadequate 'wheel specialists' being unable to properly diagnose the problem).
Rekin, I see you've already done a lot of what I did (bushes/rack etc), and doubt your problem is related to mine, but for those with the shakes over 100kph, check this out:
Steering wheel shakes at speed
haha yeah ive spent so much time trying to fix this problem;
- Several wheel balances and alignments
- camber, castor, subframe, power steering bushes
- replaced whole steering rack
- More wheel balances and alignments
- balanced tailshaft
- Replaced tyres/rims
- Balanced them too
Only step left is to rebalance clutch/flywheel or get a replacement through warranty...
- Balanced them too
Did the grease monkey put the pins back in that hold the clutch central after it was machined or leave them out ? i have seen this before and it caused a vibration but it was car speed unrelated only vibrated when you hleb the reves up ,. your problem is realtive to wheel speed not car engine rpm ? if so check wheel bearing and all the other garbage,
my 2 cents
I've just noticed a bad vibration in my Stagea. I had an R33 GTR gearbox and R34 GTR clutch installed 6 months ago, and apart from a transfer case failure never had any real vibration. It's not related to revs, and comes on after 40km/h, and get gradually worse until about 80km/h then stays constant. from reading this thread it sounds like something has gone in the driveline, like a bearing or uni joint. does anyone have any experience with uni joint or bearing failures and what they should feel like?
yeah i went for a test and noticed that;
at 100km/h+
- Clutch pressed whole way in + selected gear (4/5) still has vibrations
- Neutral rolling at 100km/h still have vibrations.
Does that rule out it is the clutch/flywheel imbalance?
  • 3 weeks later...
- Balanced them too
I'm with godzilla67 my moneys on the dowell pins in the flywheel not being replaced,I spoke to Jim Berry at length about flywheels and clutches and he told me that he's seen some really stupid butchery done on them to get them out but laziness,time constraints and the wrong tools adds up to some mechanics or flywheel grinders just grinding them down so they can machine the flywheel in the assumption that the mechanic will get the stubs out after machining and replace them with new ones but some just refit everything and forget or don't know any better.
Jims solution was to get the dowell pins out and drill a tiny hole maybe 2mm right through the dowell holes so next time it's just a matter of punching them out from the other side,he also said replacing pins that have been taken out the butchers way should be mandatory and owing to my concern put dowells in the package with my clutch.Cheers Grey Pearl.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
