This exact problem has occured to me this week. I have an rb25det in a 180sx, and have just had my os giken clutch removed to have the plates re-made (dead clutch). Clutch was re-made by local clutch shop, and put back in by the workshop. When the car reaches approximately 90km/h there is a humming sound, and vibration coming from the tailshaft area, seems to be coming from just before the diff area.
The vibration is not noticeable in first or second gear, only in 3/4/5th gear, above 90km/h.
If i put the car in neutral in 3/4/5th gear, the vibration/humming sound is still there.
The mechanic states he placed an indicator chalk mark on the tailshaft upon removal, and re-installed it at the same spot, as from previous experience if the tailshaft is not placed back at the exact position, then vibrations can occur.
I've never removed the tailshaft personally before, but I can see that it has 6 allen key bolts that bolt to the joiner for the diff. In the centre of those 6 bolts, I assume there is a spline? I was thinking the spline may be a tooth or two out, but i can't see how this is possible, if there are 6 bolts lined up in place? Is there a spline in there? Here's an old pic of my tailshaft/diff;
Edited by silman
  • Replies 51
ok, just got back from the shop. Found out that the spline is just on the gearbox side. The 6 allen key bolts on the diff side of the tailshaft were done up by another employee of the shop, and that guy had done up the bolts, 1 at a time clockwise.
Another employee loosened all of the bolts, then re-seated the tailshaft, and then tightened the bolts up in a star pattern. I took it for a drive, and the majority of the vibration is now gone. There's still perhaps a 5/10% vibration there, as opposed to say 30% previously. To people who have vibration problems after a clutch install, try this as a fix. Make sure the mechanic marks the tailshaft position mark before removing it.
Edited by silman
Buds,
My goodness. I have the exact same problem with my series 2 GTS. Got the car 4 weeks back and have been pissed just trying to fix the problem. Car vibrates at 110 all the way to speed cut at 180 km. Same on power, off power and in neutral and even with clutched depressed. Changed rims, tyres, balance etc. Same crap.
Got the prop shaft removed yesterday and doing a balance now. Centre bearings all look ok. Will ask the mech to tighten the nuts in a star formation and see if this helps too. Just cant stand the vibration.
Will update if this solves the problem.
Cheers
Buds,
Cheers
Update 10/5/08
Changed both drive shafts.
Installed balanced long shaft. Same problem.
Will remove and reattach the 4 lugs which go to the back LCD diff in a 180 rotation on Monday.
Last thing to do is change the gear box bearing which attaches to the long shaft.
Dont know what else to do.....
Edited by opp61
Update 10/5/08
The thing I notice with a lot of posts about faults that occur after work has been done on a vehicle is that people fix everything unrelated to the problem trying to fix it, when what you need to ask yourself is was this problem present before the work was done,if not then it is first and foremost related to the work that was done and therefore your first port of call should be to take it back to where the work was done and tell them that it wasn't doing it when you brought it there and you want it fixed at their expense.
Also in order to make them aware of this fact you need to let them drive it ,if it is driveable,before you leave it, then there will be no argument as to whether the problem was already present when the car was dropped off.Grey Pearl.
Took my car back to suspension workshop. They removed all my aftermarket bushes, regreased them, fitted and wheel alignment. (camber, castor)
Vibration seems to be gone now..very interesting haha
The vibration was present before/after I had my bushes first installed, but now the vibration is gone once they re-installed them..
So, my results;
- Vibration after clutch installed (vibration)
- New adjustable bushes installed (vibration)
- Tailshaft balanced (vibration reduced 50%)
- Adjustable bushes refit (vibration reduced 90-100%)
So balancing the tailshaft and refitting the bushes has removed the vibration.
Anyone know what the problem could have been?
So, my results;
Bud
The bushes would be the last on my list of options but hey if it worked for you, i would give it a shot tomorrow.
Will update if is cures my nighmares.
Cheers
Edited by opp61
Bud,
When I got this car 4 wks back, the vibration was already present. I brushed it off as maybe a wacked rim or bumpy tyres. They previous owner said that he hasnt done any balancing on the tyres for sometime as the car has not been driven for some time.
That was when my nightmare started.
Bud,
Buds
Done the following today
1) Changed gbx mounting
2) Check bushes on subframe and rear suspension.
3) Changed gbox and rear diff oil
4) Confirmed that the long shaft is in sync.
5) Balanced the long shaft
AND IT STILL VIBRATES !!!!!!!!
Running out of ideas. Anybody got any more ideas?
Buds,
Summary of what has been done:
1) Changed both rear drive shafts
2) Change rear wheels (borrowed)
3) balanced long shaft
4) Center bearings ok.
5) Aligned cv joints
6) Vibration is on throttle, off and even with clutch in.
7) Changed gbox and diff oil
8) Changed gbox mounting
9) Checked all the suspension bushes.
Done today 15/5/08
1) New rear axel
2) Changed front wheels (borrowed)
3) Fabricated a size reduction rear piece to fit into my 4 inch Kakimotor rear muffler ( wow the car is so much more silent)
Conclusion: Still vibration at 110km+ all the way to speed cut at 180 km. When the vibration happens, there is a dull vibration which comes from the back and you can actually hear is. ( not very loud)
What else should I look at?
Wheel bearings are all ok. No funny sounds. Spin ok.
However is sound the only way to know if the wheel bearings have failed?
Really need some help on this issue.
Buds,
Done today 15/5/08
1) New rear axel
I'm suss on the centre tailshaft bearing even if they said it was alright get a second opinion,I have learn't so many times that self diagnosis is the worst advice you'll ever get unless you are a good mechanic,anyway at the worst you'll have nearly re-coed the car and will reap the rewards in the future.Good luck Grey Pearl.
Bud
The whole of last week the car was at the mechanics place. Some parts purchase and some borrowed. i.e. rear axel, wheels etc
Changed the rear bearing today and still the same problem.
I have given up on finding the root cause of the problem. My mechanice has also give up. He can't charge me for the 1 week of work as the vibration is still there. That poor bugger is only charging me for the gbox oil and long shaft balance. I will buy him some beer for his help.
Will drive the car like normal and pretend that there is no vibration at all .
I have given up.
TKO by the Skyline GTS on me !!!
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
