  • 6 months later...
Yes it needs to be calibrated precisely if you want it to be accurate. speed comes from rolling wheel diameter (wheel centre to ground x 2) from memory. Factory stock is 1 or 100%. I think mine worked out at 102%. Or it could be rolling circumference.
Just anopther question.. does anybody know which wire is the spped out wire? I know the rev wire is the white wire.. But the manual on the net at apexi does not say which wire is the speed out wire? Has any body got a hard copy of the instructions and could help me out? Thanks..
There IS a setting for this n the etc. menu somewhere.
When i had mine installed it never went over about 5 kms/hr.
Went and changed the value of ....i forget....but it then read about half of what i was doing ie......read 40 when doing 80, then changed the same value again and it was spot on....except for adjusting to about 104% for fine adjustment.
It says in the instructions somewhere and it's to do with how many pulse each car sends per whatever. It's VERY easy once you find out which value it is.
Yeah, i have that sorted out.. The rsm reads exactly what the dash says, but im now after the speed out wire from the rsm.. to an external device.. ie radar detector etc.. anyone have the instruction which says which wire is the speed out wire? I know the white wire is the rpm wire.. which wire is the spped wire?
Thanks
which wire is the speed wire?
The US manual doesn't list a colour for the speed output although something in the back of my head says Grey?
If we look at the Jap manual though, there is a japanese character next to the speed output wire where the colour should be shown in the US manual. It appears that this info has been lost during translation.
Someone who can read japanese should be able to tell us what colour the attached character stands for.
OK...here we go
Red.........Ignition/Power
Yellow.....RPM signal
Black.......Ground
Purple.....Speed Signal...Loom side
Pink/Peach..Speed Signal...ECU side
White......Speed/RPM warning output
Grey........Speed/RPM warning output
2 wires not used
Brown....SP2 output??
Blue.......SP2 Input??
In the Japenese instructions for ECU hookup use diagram N4_c on page24.
Top row 7-2 is wire 50....ECU ground...Black
The other one is wire 7....RPM Signal...Yellow
Bottom row IG is wire 59....Power Supply....Red
next one is Wire 53....Speed sensor....cut it...Purple to loom side...Pink/Peach to ECU side
My APEXi RSM worked fine
You guys beat me too it! I was going to write up the full wiring colour coding.. damn it! Anyways, when you use either the rpm or speed out warning.. you need to use a relay inline to your item. I my case, i used an led, with a flasher unit i made to make it flash like a pivot shift etc. It works fine and dandy!
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
